2016 Hyundai Sonata Alarm Wiring
Reeceddogg
Copper - Posts: 329
Posted: July 10, 2018 at 10:43 AM / IP Logged Link to Post Post Reply Quote Reeceddogg
Looking for the the r/s alarm wiring for a 2016 sonata
wirewise
Moderator - Posts: 489
Posted: July 10, 2018 at 10:53 AM / IP Logged Link to Post Post Reply Quote wirewise
SONATA      2011-2016
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, VEHICLES WITH SMART KEY AND PUSH TO START REQUIRE A DBALL2 INTERFACE FOR REMOTE STARTING. See NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      GREEN (+), NOTE #2      @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 1
STARTER      YELLOW (+), NOTE #3      @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 3
STARTER 2      YELLOW/BLACK and YELLOW/ORANGE (+) (PUSH-BUTTON START)      @ START/STOP BUTTON SWITCH, (BLACK, 10-PIN PLUG), PINS 1 and 7
IGNITION 1      PINK (+), NOTE #4      @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 4
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      ORANGE (+), NOTE #5      @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 2
ACCESSORY/HEATER BLOWER 2      BLUE (+), NOTE #6      @ IGNITION SWITCH, WHITE, 6-PIN PLUG), PIN 6
KEYSENSE      N/A
PARKING LIGHTS ( - )      PINK (-)      @ HEADLIGHT SWITCH or BCM, (GRAY, 24-PIN PLUG), PIN 22, NOTE #9
PARKING LIGHTS ( + )      GREEN/BLACK(+)(Left) and BROWN/BLACK(+)(Right) use both      @ DASH FUSE BOX, (BLACK, 39-PIN PLUG(A), PINS 25 and 7
POWER LOCK      WHITE (-), TYPE B      @ DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PIN 13
POWER UNLOCK      YELLOW (-), TYPE B, NOTE #7      @ DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PIN 1
LOCK MOTOR WIRE      PINK/BLACK (+), 5-Wire Type      @ DASH FUSE BOX, (BLACK, 39-PIN PLUG(A), PIN 34
DOOR TRIGGER      BROWN (-)      @ DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PIN 7
DOMELIGHT SUPERVISION      YELLOW/BLACK (-)      @ BCM, (WHITE, 24-PIN PLUG), PIN 4, NOTE #9
TRUNK RELEASE      WHITE (-)      @ TRUNK RELEASE SWITCH or DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PIN 2
SLIDING POWER DOOR      N/A
HORN      WHITE (-)      @ HORN SWITCH or in DRIVERS KICK PANEL, (WHITE, 43-PIN PLUG), PIN 42
TACH      WHITE, BLUE, YELLOW or ORANGE, (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      GREEN or GREEN/ORANGE (+)      @ BRAKE PEDAL SWITCH or in DRIVERS KICK PANEL, ( WHITE, 43-PIN PLUG), PIN 34
FACTORY ALARM DISARM      ORANGE and BROWN (-), Requires Double Pulse, NOTE #8      @ DASH FUSE BOX, (WHITE, 24-PIN PLUG(D), PINS 16 and 22
ANTI-THEFT      HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1      @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: This vehicle May Be Equipped with HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, check the OWNERS MANUAL for this vehcile or contact your HYUNDAI Dealer to see if the vehicle has a Special programmed Ignition Key, if it does, then for REMOTE STARTING you will need the 791 BYPASS Module and an Extra Ignition key. Vehicles with SMART KEY AND PUSH BUTTON START AN INTERFACE MODULE PART #DBALL2 IS REQUIRED FOR REMOTE STARTING.
NOTE #2 use GREEN, RED and PINK (+) 60 AMP, at the DASH FUSE BOX, (BLACK, 3-PIN PLUG(C), PINS 1, 2 and 3.
NOTE #3: on Vehicles with SMART KEY, use YELLOW (+), at the DASH FUSE BOX, (REAR BLACK, 39-PIN PLUG(E), PIN 39
NOTE #4: on Vehicles with SMART KEY, use PINK (+), at the DASH FUSE BOX, (REAR BLACK, 39-PIN PLUG(E), PIN 14
NOTE #5: on Vehicles with SMART KEY, use ORANGE(+), at the DASH FUSE BOX, (REAR BLACK, 39-PIN PLUG(E), PIN 1
NOTE #6: on Vehicles with SMART KEY, use BLUE(+), at the DASH FUSE BOX, (REAR BLACK, 39-PIN PLUG(E), PIN 27
NOTE #7: to UNLOCK just the DRIVERS DOOR use the YELLOW/ORANGE(-) at the DASH FUSE BOX, (REAR WHITE, 24-PIN PLUG(F), PIN 10
NOTE #8: TEST these wires while Turning the KEY in the DRIVERS DOOR
NOTE #9: the BCM, (Body Control Module) is located under the DRIVERS DASH, above the GAS PEDAL.
~wirewise~ Verify all wiring with your meter before making any connections!
the12volt
Administrator - Posts: 3,955
Reeceddogg
Copper - Posts: 329
Posted: August 05, 2018 at 2:06 PM / IP Logged Link to Post Post Reply Quote Reeceddogg
Im trying to install a remote start alarm in a 2016 sonata but the wiring on here does not match the car, mainly at the fuse box. can someone update this.
the12volt
Posted: August 05, 2018 at 2:28 PM / IP Logged Link to Post Post Reply Quote the12volt
Your last post says you're looking for wiring for a 2017 Sonata. Which is it, 2016 or 2017?
2016 Hyundai Sonata Alarm Wiring - Last Post -- posted image. the12volt • Support the12volt.com
Reeceddogg
Copper - Posts: 329
Posted: August 06, 2018 at 12:45 AM / IP Logged Link to Post Post Reply Quote Reeceddogg
I originally asked for a 2016 and it's wrong. Maybe a 2017 will be right.
the12volt
Posted: August 06, 2018 at 12:45 PM / IP Logged Link to Post Post Reply Quote the12volt
Reeceddogg, if you can, please list what you have found in the 2016.
Thanks in advance!
Reeceddogg
Copper - Posts: 329
Posted: August 06, 2018 at 8:07 PM / IP Logged Link to Post Post Reply Quote Reeceddogg
I'll get pics and report back
badyr_s66
Posted: September 22, 2018 at 9:40 PM / IP Logged Link to Post Post Reply Quote badyr_s66
Raceddogg, have you had any luck finding the 2017 diagrams for the Sonata?
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
