Create Signal from Latched Ground Output to Momentary Ground Pulse
miketheman
Member - Posts: 13
Posted: November 01, 2019 at 9:04 AM / IP Logged Link to Post Post Reply Quote miketheman
I have a vehicle GPS tracker that when commanded will put out a latched ground output meant to control a relay such as a remote fuel cut off if the vehicle gets stolen. I also have a remote starter installed in the vehicle that has a single ground activation wire, and rather than paying a monthly fee for a second device I want to use the ground output from the GPS tracker to pulse the activation wire on the remote starter. I know how to create a pulse to latched relay circuit but not sure how to do it the other way around.
Thanks in advance.
the12volt
Administrator - Posts: 3,955
Posted: November 01, 2019 at 9:08 AM / IP Logged Link to Post Post Reply Quote the12volt
Look at the constant to momentary output diagrams here: https://www.the12volt.com/relays/relaydiagrams.asp
Create Signal from Latched Ground Output to Momentary Ground Pulse - Last Post -- posted image. the12volt • Support the12volt.com
the12volt
Posted: November 01, 2019 at 9:10 AM / IP Logged Link to Post Post Reply Quote the12volt
miketheman
Member - Posts: 13
Posted: November 02, 2019 at 8:34 PM / IP Logged Link to Post Post Reply Quote miketheman
This looks good but won't it is cause a drain on the battery when the vehicle is off?
eguru
Copper - Posts: 340
Posted: November 05, 2019 at 7:01 AM / IP Logged Link to Post Post Reply Quote eguru
Thanks in advance.
Just capacitively couple the input with a 470uF capacitor (positive to the input). Add a 1K pullup resistor from the input to +12V. No relay required.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
