I keep blowing subs! help!
Okoboji
Member - Posts: 35
Posted: June 23, 2003 at 10:03 PM / IP Logged
Where do you live? was your car out in the sun before you turned it on? how hot does it get in your trunk? your voice coil might have been over heated and playing it could have pushed it over the edge
Okoboji
"Yo I wanna buy a system so big it blows women's clothes off!"
phredman
Member - Posts: 24
Posted: June 24, 2003 at 7:48 PM / IP Logged
ohio,It was kinda cool ,around 70.it was in a bmw 323,I even punch out  the ski pass ,this really stumps me .....
fuseblower
Silver - Posts: 403
Posted: June 25, 2003 at 12:54 PM / IP Logged
phredman, If you smelled an electrical burn and your amp did not go into protection your subs over heated.  There could be many factors that could cause this to happen.  Orion amps are very under rated in some cases.  If you remove your sub from the box and it smells like it burnt than you are either over powering your sub or sending massive amounts of distortion to it.  But since you said the amp is turned down it is possible that you are over powering the subs.  The easiest way to resolve this is to get a sub that handles more power or upgrade to a dual sub system.
Another reason that your sub could have burnt out is because of the break in period.  Most subs require hours of play at above average levels but not to be pushed to the max for hours before they actually achieve there best performance.  Can't answer why is this but after talking to varoius sub makers this seems to be a reality.
Hope that this helps
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
