fuse box problem
jlseven
Posted: July 16, 2003 at 12:21 PM / IP Logged
i hardwired my radar detector to my fuse box using a fuse blade tap.  i first tried the radio fuse, but the detector wouldn't shut off when the car was turned off. i then tried the airbag fuse and it worked. the problem is that the tap widened the space for the radio fuse to the point that the fuse is loose and the only way to make the connection is to leave the tap in. is there any way to tighten the connections for the loose fuse?
Moderator - Posts: 12,488
Posted: July 18, 2003 at 11:42 PM / IP Logged
take a needle pick and pry the terminals closer.
copcarguy
Copper - Posts: 122
Posted: July 19, 2003 at 9:27 AM / IP Logged
put another fuse tap in where you pulled it out and just don't use it.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
jlseven
Posted: July 22, 2003 at 12:47 PM / IP Logged
thanks for the helpfuse box problem - Last Post -- posted image.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
