93 altima trunk light
Tcole
Copper - Posts: 92
Posted: July 28, 2003 at 11:30 AM / IP Logged
I am installing neon the trunk. I dont have a multimeter, so I was wondering if anyone knows if the positive lead is red or red with black stripe?
wire4veins
Copper - Posts: 97
Posted: August 06, 2003 at 4:08 AM / IP Logged
huh?
Moderator - Posts: 12,488
Posted: August 06, 2003 at 8:22 AM / IP Logged
The RED is a (-) trigger, if that helps you.
Tcole
Copper - Posts: 92
Posted: August 07, 2003 at 1:44 PM / IP Logged
So does (-) mean it is a ground or a hot wire. I hooked up the - neon lead to the trunk light ground source. I hooked the + neon lead to the + trunk light power source.
Everything works the way I want and it looks great.
I am a little confused about the RED(-)thing, because the RED is the 12v power so shouldn't it be RED(+)?????
Sorry for the ignorance on this subject but maybe someone can explain.
Thanks for the help.
krazypolishboy
Member - Posts: 17
Posted: August 16, 2003 at 2:25 AM / IP Logged
with neons as long as the wires stay the same the whole way through its fine. for example if your putting in a underbody kit for example, as long as you use the black wire with the stripe as a positive for all of the neons, and the solid black as a negative for all the neons then it'll work fine, and vice versa.
Tcole
Copper - Posts: 92
Posted: August 17, 2003 at 4:06 PM / IP Logged
Thanks I've got it installed.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
