98 Saturn SC1, installed a AutoPage R/S
gpgtp00
Copper - Posts: 81
Posted: December 16, 2003 at 2:56 PM / IP Logged
Im having a problem here. Sometimes the car will remote start and stay running and other times it will start up, run for no more than 30 seconds or so, then turn off and repeat that process 3 times til it quits trying. What gives? Thanks
Geeque
Silver - Posts: 310
Posted: December 16, 2003 at 3:58 PM / IP Logged
Sounds like your having a problem with the passlock 2 bypass, check those connections, make sure you have the right resistance.
Gary Kline
MECP Master Technician
gpgtp00
Copper - Posts: 81
Posted: December 16, 2003 at 4:03 PM / IP Logged
theres no passlock on this car.
Geeque
Silver - Posts: 310
Posted: December 16, 2003 at 4:06 PM / IP Logged
Where are you getting the main power for the r/s at?
Gary Kline
gpgtp00
Copper - Posts: 81
Posted: December 16, 2003 at 4:12 PM / IP Logged
the ignition switch harness. i think i already know what your gonna say.
JWorm
Platinum - Posts: 2,208
Posted: December 16, 2003 at 10:04 PM / IP Logged
What wire are you using for tach? Does the problem happen when the car is only hot, cold, or both? I recommend using one of the injector wires on that car for tach.
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 10:22 AM / IP Logged
Also run the main power wire to the battery. Also I think i remeber some sort of problem i had with a factory alarm module behind rear passenger B pillar i had to interupt a circuit there for some reason. Not sure if the vehicle has a security system or not , but you might want to post a forum to see if this is an issue or not.
Gary Kline
