2004 Chevrolet Impala Alarm/Remote Start Wiring
Fredskmgi
Member - Posts: 9
Posted: May 27, 2004 at 1:26 PM / IP Logged
Does anyone have a Stereo and Alarm wiring diagram for a 2004 Chevy Impala? Thanks.
jfk51502003
Copper - Posts: 221
Posted: May 28, 2004 at 4:08 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / IMPALA / 2004 / Remote Start
[PRINT THIS PAGE]
12voltsred (x2)(common 60A) + ignition harness
Starteryellow + ignition harness
Second StarterN/A
Ignitionpink + ignition harness
Second Ignitiondk. green + ignition harness
Third IgnitionN/A
Accessoryorange + ignition harness
Second Accessorybrown + ignition harness
Notes: This wire must be powered as an accessory wire. If powered as a second ignition, the car will not crank.
Keysenselt. green - ign harn or BCM, gry 16P plg, pin B1
Notes: The BCM is under the driver side dash, above the parking brake lever.
Power LockORANGE / black - BCM, gray 24 pin plug, pin B3
Notes: Lock is negative trigger thru a 470 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlocksame wire as power lock
Lock Motorsee notes
Notes: Installation of factory keyless upgrade alarm is not recommended on this vehicle because the door lock motor wires rest at approximately 7 volts.
Unlock Motorsee lock motor notes
Parking Lights+yellow (F), BROWN / white (R) + passenger junction block end of dash
Parking Lights-white - BCM, pink plug, pin A2
Must diode isolate this wire from the BCM to avoid Service Engine Soon light. See DirectFax document 1600 for wiring information.
Hazardssame as turn signal wires
Turn Signal(L)lt. blue (F), yellow (R) + steering column
Turn Signal(R)dk. blue (F), dk. green (R) + steering column
Reverse Lightlt. green + passenger junction block end of dash
Door Triggerdk. blue (L), dk. blue/wht (R) - BCM, gray 16 pin plug, pins A8, A1
Notes: Use both wires and diode isolate each.
Dome Supervisiongray - BCM, gray 24 pin plug, pin A8
Trunk/Hatch PinRED / black - BCM, gray 24 pin plug, pin A11
Hood PinN/A
Trunk/Hatch Releaseblack - BCM, gray 16 pin plug, pin A7
Power Sliding DoorN/A
Factory Alarm Armarms on lock with door open
Factory Alarm Disarmlt. green - BCM, gray 16 pin plug, pin B3
Disarm No Unlocksee factory alarm disarm
Tachometerwhite ac Ignition Control Module
Notes: On the 3.4L it is on the top center rear of the engine. On the 3.8L it is on the top right front of the engine.
Wait to startN/A
Brake Wirewhite + brake pedal switch
Parking Brakelt. green - BCM, gray 16 pin plug, pin B6
Horn Triggerblack - BCM, pink plug, pin B5
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
2004 Chevrolet Impala Alarm/Remote Start Wiring -- posted image.
Immobilizer Bypass Module:Required: YesType: Passlock 2Part #: 555L or 555T
Notes: The Passlock 2 wire colors are yellow, black, and white (not used).
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
