2k Dodge Ram
jmyinc
Copper - Posts: 59
Posted: September 03, 2002 at 7:58 PM / IP Logged
I installed an alamr on a 2000 Ram today. When I remote started it the check engine light stays on. Then I started it with the key and it comes on again. I reset the computer (taking the neg. batt. terminal off) and when i start with the keyit Does not come on, the i remote start and it comes on, and then with the key.
Any one know whats wrong.?
-Morgan
mobiletoys2002
Gold - Posts: 1,050
Posted: September 03, 2002 at 8:36 PM / IP Logged
Second ignition needs to be powered this will happen everytime. You must have not conected it, you are lucky the light went out without a trip to the dealer find the second ignition and make sure you power it while remote started. Look for a BLACK/ orange wire at the ignition this should be the problem wire.
