1999 Ford fiesta (EU) Wiring Diagram
ez_thefix
Posted: June 21, 2004 at 5:00 AM / IP Logged
I need a wiring diagram for a 1999 ford fiesta studio (european).
I am planing to install a compact alarm. I am thinking that if I don't install any remote entry, the instalation should be pretty simple; the car already has a factory starter kill, which I would leave intact. All I need is for the siren to go off if someone tried to break in to steal anything inside. I am looking at this micro scan model: AN313 - 116.99 (RRP £137.99)  http://www.microscanalarms.co.uk/system/index.htm
Thanks!
jfk51502003
Copper - Posts: 221
Posted: June 22, 2004 at 10:58 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / FIESTA (UK) / 1999 / Security
[PRINT THIS PAGE]
12volts
Starterblk/blu or grey ignition harness
Ignitionblack or green ignition harness
Power Lockyel/blk or yel/blu + either kickwell
Power Unlockwht/vio or wht/grn + either kickwell
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+blue & blu/red at the steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door TriggerBLACK/ red - n/s kick panel
Dome Supervision
Trunk/Hatch PinORANGE / black at the bootlight
Hood Pin
Trunk/Hatch ReleaseORANGE / black at the release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
TachometerWHITE/ blue alternator
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
1999 Ford fiesta (EU) Wiring Diagram - Last Post -- posted image.
Immobilizer Bypass Module: Not Available
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
