Door locks 2003 Taurus
saleen49
Copper - Posts: 99
Posted: October 31, 2004 at 12:50 AM / IP Logged
 I installed an A/S on my 03 Taurus and all i need to do yet is the keyless entry, I have a GEM module and all of the wiring charts my alarm has - trigger outputs for lock/unlock can i just connect to the proper wires at GEM or is there more to it then that? also i remember having to wake up the GEM on my brothers Explorer when we installed a unit on his truck last year and remember not using any relays for his locks,
 thanks
kenmci
Copper - Posts: 161
Posted: October 31, 2004 at 12:57 AM / IP Logged
usually to wake up the GEM module you need a second pulse from the unlock wire to wake up the module and unlock the doors at the same time, having said this I have never had a problem with the Gem module not waking up and usually you can just connect to the unlock wire and everything works fine.  Just my opinion though.
deviousjoker
Copper - Posts: 102
Posted: October 31, 2004 at 12:23 PM / IP Logged
I believe your door lock wire are at the smart junction box below the fuse box.
First Class MECP Installer
saleen49
Copper - Posts: 99
Posted: October 31, 2004 at 4:42 PM / IP Logged
 The pink / YELLOW & pink/green at the bottom of the GEM did the trick, works great,
 thanks again
saleen49
Copper - Posts: 99
Posted: November 01, 2004 at 2:09 PM / IP Logged
  What would cause the unit to keep rearming and triggering an alarm while i have the door and hood open?, I have the passive alarm set to off but somthing is causing it to rearm and trigger, it is a mannix sm700 a/s,
 all i have hooked up are the door locks to pink / YELLOW & pink/green at gem, dome light supervision at kick panel and door trigger input,
 thanks
draasch
Gold - Posts: 2,172
Posted: November 01, 2004 at 2:16 PM / IP Logged
if the alarm is arming with the door open, it sounds like you dont have the door trigger wire hooked up...
should use this wire in the car:
Dome Light YELLOW (-) AT INTERIOR LIGHT
the alarm may have it listed as a - door trigger
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
saleen49
Copper - Posts: 99
Posted: November 01, 2004 at 3:31 PM / IP Logged
 I must of hooked it up wrong, I have the trigger input going to 87a as part of a + relay  with 86 to - dome light output at alarm 85 & 87 to +12v & 30 to dome light wire in kick panel, I get dome light on when i use mannix keyless entry/alarm disarm but am getting the triggering/rearming when the doors are open,
draasch
Gold - Posts: 2,172
Posted: November 01, 2004 at 5:32 PM / IP Logged
Make:   Ford
Model: Taurus
Year:    2003
Alarm
Constant 12 volts LT.GREEN/ VIOLET IGNITION SWITCH HARNESS
Ignition 12 volts RED / LT.GREEN IGNITION SWITCH HARNESS
Starter RED / LT.BLUE IGNITION SWITCH HARNESS
Trunk Pin Switch WHITE/ YELLOW (-) AT MODULE TO LEFT OF STEERING COLUMN
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW DRIVERS KICK PANEL #201
Power Unlock PINK/GREEN DRIVERS KICK PANEL
#201 See Negative Pulse Door Lock Diagram
i dont have any notes talking about the GEM unit on this car........what wire from the alarm do you have hooked up to the dome light listed above????? and what is the polarity of the wire coming from the alarm?//
Good Luck
David
Ace Security
813-376-9778
Tampa
draasch
Gold - Posts: 2,172
Posted: November 01, 2004 at 5:33 PM / IP Logged
also does your LED flash a number of times to indicate what zone triggered the alarm?????
Good Luck
David
Ace Security
813-376-9778
Tampa
saleen49
Copper - Posts: 99
Posted: November 02, 2004 at 4:06 PM / IP Logged
 OK,
 I found that leaving the hood open triggers an alarm when rearming occurs,
 I have the 30 on relay to black with light blue strip that shows +12v when door is opened with a test light, it only triggers an alarm when hood is open but the alarm keeps rearming with doors open or closed and i have this option turned off,
 Lastly this unit only has one (-) ignition output  trigger but i have two items wired to it with out using diodes as directed in my manual and it works fine but am worried that this might not be a good idea and am open to comments on this,
 thanks for the help,
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
