wiring problem with a 2002 lancer
gfella2000
Member - Posts: 28
Posted: December 28, 2004 at 2:09 PM / IP Logged
Mitsubishi Lancer 2002
wiring problem with a 2002 lancer - Page 2 - Last Post -- posted image.
wiring problem with a 2002 lancer - Page 2 - Last Post -- posted image. Remote start / Security / GPS
Wire/FunctionColourLocation/DescriptionPolarity
12 VOLTS White Ignition switch harness +
IGNITION BLACK/ white Ignition switch harness +
ACCESSORY Blue/white Ignition switch harness +
STARTER BLACK / YELLOW Ignition switch harness +
TACH BLACK / YELLOW or BLACK/ green At either of 2 coils on top of engine AC
CRANKSHAFT POSITION SENSOR BROWN / green On lower front of engine*
FUEL INJECTOR Opposite from RED / yellow At any injector on engine AC
LOCK Violet On junction block above DKP -
UNLOCK Lt.green On junction block above DKP -
DOORPIN Black On junction block above DKP -
TRUNK PIN GREEN/ orange At light in luggage compartment -
BRAKESWITCH Green At switch above brake pedal +
PARKLIGHTS GREEN / WHITE On junction block above DKP +
HAND BRAKE BLACK/ red At switch on handbrake lever -
HORN Yellow At steering column -
CLUTCH SWITCH Blue/orange At switch above clutch pedal TYPE 4
DRIVER WINDOW UP RED / black At switch in driver's door REV POL
DRIVER WINDOW DOWN GREEN/ black At switch in driver's door REV POL
PASSENGER WINDOW UP Blue/white In driver's kickpanel REV POL
PASSENGER WINDOW DOWN BLACK/ white In driver's kickpanel REV POL
LEFT REAR WINDOW UP White In driver's kickpanel REV POL
LEFT REAR WINDOW DOWN Blue In driver's kickpanel REV POL
RIGHT REAR WINDOW UP Blue/black In driver's kickpanel REV POL
RIGHT REAR WINDOW DOWN GREEN/ YELLOW In driver's kickpanel REV POL
HEADLIGHTS RED / black On junction block above DKP +
REVERSE LIGHTS Brown Under driver's side running board +
VSS WIRE BLACK / YELLOW Pin-8 at PCM behind glovebox
KEY SENSE Blue/red Ignition switch harness -
wiring problem with a 2002 lancer - Page 2 - Last Post -- posted image. Vehicle notes
* Also found at pin-45 of connector C-118 connector of PCM behind glove box.
Keep in mind that none of the Mitsubishi Lancer's have a transponder in the key
gfella 20000000000
gfella2000
Member - Posts: 28
gfella 20000000000
jaurora
Silver - Posts: 429
Posted: December 28, 2004 at 2:25 PM / IP Logged
Keep in mind that I do alot of mitsubshi lancers, I have a contract with a mitsubishi dealership. I have had both types come in. Some do have the transponder some of them dont. This all depends on what plant that the car was made at.  "KEEP IN MIND THAT SOME OF THE LANCERS HAVE A TRANSPONDER KEY" Note that I have never said all!!!!!!!
MECP certified (If it really means anything)
Jeremy
jaurora
Silver - Posts: 429
Posted: December 28, 2004 at 2:26 PM / IP Logged
Jeremy
evergrin9904
Member - Posts: 9
Posted: December 28, 2004 at 4:47 PM / IP Logged
Well guys ill give it another try. My wife said if its not done by tonight then to take it out, so this is kind of my final shot at it. I thank you all very much for the useful information i will use it when im working on it tonight. thank you for being so kind.
evergrin9904
evergrin9904
Member - Posts: 9
Posted: December 28, 2004 at 7:32 PM / IP Logged
ok guys, ive tried the key in the ignition, it did start the car, however when i did turn it to run the car started so i dont know if it is still the transponder, or maybe a wire any more ideas would be great thanks.wiring problem with a 2002 lancer - Page 2 - Last Post -- posted image.
evergrin9904
evergrin9904
Member - Posts: 9
Posted: December 28, 2004 at 11:39 PM / IP Logged
well i got everything installed a-ok. thanks to everyone's help i appreciate it greatly!!!
evergrin9904
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
