remote start
c3d
Copper - Posts: 45
Posted: February 06, 2005 at 3:58 PM / IP Logged
hey, I am installing a polarstart remote start in my 1988 toyota celica. Have a few questions.
1. They grey connection goes to the hood pin switch, then is the connection completed by the hood pin switch being grounded out to the frame?
2. There are many wired that Don't seem to be needed for my application, is this true? the wires are:
12-pin harness (none of them seem to apply to my application).
Parking Light (+)
12V Battery (the second one)
5th auxilary output
Any help would be appreciated
KarTuneMan
Platinum - Posts: 7,056
Posted: February 06, 2005 at 4:29 PM / IP Logged
On a remote start, you need to use all of the 12v. connections. They give voltage to the internals of the unit.
The 12 volt parking light wire is for the light flash. You don't NEED to use it, but without it no light flash.
The aux outputs....NOPE, unless your doing more than a "basic" job
c3d
Copper - Posts: 45
Posted: February 06, 2005 at 5:26 PM / IP Logged
cool. since you work at a dealer, do you have access to the diagram i need? if so, can i get a copy? if not, oh well. And about the hood pin switch. Was what i said right?
daniel2002p
Silver - Posts: 524
Posted: February 07, 2005 at 8:08 AM / IP Logged
yup, when the grey wire sees a ground, it will not let the remote start take place.
here is the diagram
Toyota
Celica
1986-1989
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ ORANGE
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN/ RED (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK
AT IGNITER OR DASH TACHOMETER
Parking Lights:
GREEN
(+) AT FUSE BOX
Headlights:
RED / BLU (LO) & RED / WHT
(HI) (+) AT HEADLIGHT SWITCH
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
Toyota
Celica
1986-1989
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK/ RED OR WHITE
OEM Alarm Disarm:
Dome  Lights/Superv:
RED / WHITE
(-) PLUG AT FUSE BOX
OEM Horn:
GREEN/ BLUE (-)
STEERING COLUMN HARNESS
Power  Lock:
BLUE/BLACK
DRIVER'S KICK PANEL *
Power  Unlock:
BLUE
Trunk  Release:
Alarm  Input Wire:
RED / WHITE
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
c3d
Copper - Posts: 45
Posted: February 07, 2005 at 1:40 PM / IP Logged
you my savior buddy! thanks!
c3d
Copper - Posts: 45
Posted: February 07, 2005 at 8:07 PM / IP Logged
alright, i got the:
HARNESS 1:
2 (12V) battery connections done.
purple is connected to the starter output
yellow wire is connected to the ignition output
orange is connected to the accessory output
green is not used.
HARNESS 2:
black is grounded
purple is connected to the BLACK/ orange at the distributor
grey is connected to the hood pin switch
orange is connected to the brake switch
yellow is connected to the parking light output
So when I put the fuses in for the battery connections, it would flash twice, and the lights would too, so i know they work. but when i go to flash the hood pin switch, to enter programming mode, nothing happens. the hood is up. and i use the PAB button, i tried just hitting it once, nothing happens, or four 4 seconds-pause-then again once more. still nothing.
If you have any advice, pleaase let me know! I leave for work tomorrow morning for 2 weeks, and i want to get this done before i leave. thanks.
daniel2002p
Silver - Posts: 524
Posted: February 07, 2005 at 10:19 PM / IP Logged
what kind of alarm is it by the way?
    1.8L VVT-i I-4
daniel2002p
Silver - Posts: 524
Posted: February 07, 2005 at 10:21 PM / IP Logged
also make sure that the BLACK/ white wire is grounded also, if it is not grounded, it will not let the remote start start the vehicle!!
    1.8L VVT-i I-4
Ravendarat
Platinum - Posts: 2,806
Posted: February 07, 2005 at 11:39 PM / IP Logged
How do you know it has a BLACK/ white wire when he didnt state what kinda remote start is it? The DEI units have that wire but if he is flashing the hoodpin than it could be something made by a company like automobility in which case there is not BLACK/ white wire. So this brings up the previously asked question, What kinda Remote Start is it?
c3d
Copper - Posts: 45
Posted: February 08, 2005 at 8:02 AM / IP Logged
its a polarstart ps-3125sh automatic transmission remote start.and its just a black wire. and it is grounded.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
