DIRECTWIRE™ WIRING INFORMATION - TOYOTA / COROLLA / 1999 / Remote Start
[PRINT THIS PAGE]
12volts white + ignition harness
Starter red + ignition harness
Second Starter
Ignition BLACK/ white + ignition harness
Second Ignition BLACK / YELLOW + ignition harness
Third Ignition
Accessory blue/red + ignition harness
Second Accessory
Keysense
Power Lock blue/black - R side of fuse box, wht plug
Notes: The lock wires are about 18 gauge. They will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself.
Power Unlock GREEN / WHITE - R side of fuse box, wht plug
Lock Motor blue drivers kick panel
Unlock Motor red drivers kick panel
Parking Lights+ green bottom of fuse box
Parking Lights- lt GREEN/ black steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white - instrument cluster or
Notes: Also found at the fuse box. There are at least 5 RED / white wires at the fuse box, some will only pick up individual doors, meter them to find the one that will get all the doors, it will be the one that goes up to the instrument cluster, it is in a 12 pin plug on the back of the fusebox. For domelight supervision use one of the individual door triggers.
Dome Supervision
Trunk/Hatch Pin RED / white - light in trunk
Notes: On vehicle with the factory alarm, can find these wires at the alarm module above the drivers kick panel.
Hood Pin red - hood pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer yel/grn, RED / blu, gry, or wht ac any ignition coil
Wait to start
Brake Wire GREEN / WHITE + brake switch
Parking Brake
Horn Trigger GREEN/ red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.
