First system need suggestion
xxMxx
Member - Posts: 12
Posted: November 05, 2002 at 6:28 AM / IP Logged
Hi all
I got a Rockford 800.2 and I'm thinking of getting 2 Kicker 12"L7 subs. I'm just wondering if the amp has sufficient power. And do I need a Cap?If I do 1 farad or 2 farad cap should i use
Thanks for the comment.. : )
crraig wilson
Member - Posts: 13
Posted: November 05, 2002 at 10:16 PM / IP Logged
what is the amp output of you alt.?
craig wilson
xxMxx
Member - Posts: 12
Posted: November 06, 2002 at 1:36 AM / IP Logged
14.4 v.
kevin1
Member - Posts: 8
Posted: November 06, 2002 at 3:29 PM / IP Logged
A ROCKFORD 800.2 IS A PRETTY NICE AMP.  THEY RUN ON A HIGHER
POWER SUPLY WHICH MAKES THEN PERFORM AS A 1000 WATT AMP.U SHOULD HAVE NO TROUBLE POWERING UR SUBS. CAPS AND ODD NOISE TO UR SYSTEM ( U HEAR BASS WHEN CHANGING SONGS ). I WOULD SUGGEST ISOLATING A SECOND BATTERY , A GEL CELL....
I WOULD ALSO LOOK AT THE AUDIOBAHN LINE FOR SUBS! THEY POUND AND SOUND GOOD
i just picked up 2 entry line 15's and i'm rockin' out 156.9 dbs with the same amp u got.
and i have no problems!
xxMxx
Member - Posts: 12
Posted: November 06, 2002 at 4:15 PM / IP Logged
Thanks for the advice...
Reeceddogg
Copper - Posts: 329
Posted: November 07, 2002 at 9:27 PM / IP Logged
I have the same amp and it sucks all the juice out of my rockford cap, and it's a one farad. I'd go with a 2 farad and you'll have plenty of power.  also be careful of how you wire them if you have the 2 ohm dvd model
JellyNutz
Copper - Posts: 85
Posted: November 11, 2002 at 1:37 AM / IP Logged
Hahaha...  Kevin you are so wrong.  A cap will not add noise to your system, but rather filter noise out.  You ever wonder what they put in a noise filter?  Yep, you guessed right, It's a capacitor!  Sounds like you had a problem with a ground loop whenever you experienced that "Odd noise."    Audiobahn 15's rockin  156.9 db, huh?  At what frequency, and what type of enclosure?  Also, where do you put the mike at for the meter you use to measure the SPL with?  What's the Xmax on those subs?  I personally view Audiobahn as crap but everyone is entitled to their own opinion.  As far as a punch 800 pushing 1000W, it is possible, as long as you can provide it with a constant 14.4v  which is pretty much impossible without a badass charging system...  Try putting a multimeter on your power and ground terminals of the amp and see how far the voltage dips...  I bet it drops well below 14.4V!  What do you mean by "Higher power supply?"  Lemme tell ya, RF is too cheap to use a regulated power supply, and is somewhat inferior to other amps such as PPI and JL Audio (which use regulated power supplies) which will pump out the juice even at voltage drops as low as 10v!  xxMxx... as far as your question goes, the amp should be fine to power your subs.  And if you want to use a cap (Which I highly recommend) the size you need will all depend on how much amperage your alternator puts out.  If you have a weak (average) charging system, don't even think about adding a second battery, because all it will end up doing is adding a dead load to your system.  In other words, your amp will drain the second battery dead and after that you have even less juice to work with than before... Why?... because your alternator is having to charge a dead battery and power an amplifier simultaneously.  In turn, you have a even larger voltage drop to the amplifier.  Instead, try using anywhere from a 5-15F cap.  I personally prefer a Phoenix Gold Titanium Powercore.  One hell of a 15F cap!  You can sustain the voltage you need to drive that amp with an average alternator with this cap, given you run the proper size power wire and ground.  I'd personally use a 0/1 gauge wire with a circuit breaker.  I'd also upgrade my ground wire running from the battery to chassis to AT LEAST 2 gauge but preferably 0/1.  Also, with a set of equivelent ground wires running from the amp and cap SEPERATELY to the same point on the chassis, you can ensure you will not have a problem with voltage drops.  Always make sure to test the spot you are grounding to in comparison with the negative terminal on the battery to determine that you have the best "grounding potential" as possible.  All of this my friend will make sure that amp will be putting out 800w+ continuous since it does not have a regulated power supply.  If you need help with anything, feel free to drop me a line..
-Jesse
jellynutzo@aol.com
Earmark Car Audio - The Leader Loud and Clear
www.earmarkcaraudio.com
xxMxx
Member - Posts: 12
Posted: November 11, 2002 at 2:30 AM / IP Logged
Thanks jesse, that really give me the idea..I'll go for a bigger cap as you say, possibly 5 - 15F depending on my  budget. One thing that I don't understand is how to test the best grounding potential?
JellyNutz
Copper - Posts: 85
Posted: November 11, 2002 at 3:28 AM / IP Logged
Get a Digital multimeter.  Put one lead of the meter to the negative terminal of the battery, and touch the other lead to areas where you think you would like to place your ground.  Set your meter to impedence (The Omega sign) and check several place in the area to find the one with the least resistance (Lowest reading on the meter).  This will end up being your strongest ground.  Also make sure to scrape all the paint away from the point you are going to ground to, and even use a course piece of sandpaper to make sure you have nothing but bare metal...
xxMxx
Member - Posts: 12
Posted: November 12, 2002 at 5:34 AM / IP Logged
Thanks for that..
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
