era-g320 alpine eq
sickdogg
Posted: May 09, 2005 at 2:16 PM / IP Logged
i have an alpine era-g320 it works and every thing i just cant get it to turn off there is a pink wire that i did not connect cause the past user had it cut really short do i need that any 1 with helping info please replt asap i would greatly app it
sick sider for life
Chad7n7
Silver - Posts: 408
Posted: May 09, 2005 at 5:45 PM / IP Logged
Sounds like you have the swtched +12V connected to a constant source.
As for the pink wire, I am not sure as to what that is for, but try going here and downloading the owners manual.
tcss
Silver - Posts: 1,623
Posted: May 09, 2005 at 6:58 PM / IP Logged
If i could attach a file i would give you the manual....I thing you may have the wrong power plug...There is no pink wire on the Alpine ERA-g320 plug.
Do you have an e-mail adress...i'll send you the PDF of the manual
Moderator - Posts: 12,488
Posted: May 09, 2005 at 7:04 PM / IP Logged
In the past, the PINK wire is for Cell phone mute.
raydawg357
Silver - Posts: 769
Posted: May 12, 2005 at 10:25 AM / IP Logged
Make sure you didn't cross the power wires.  What HU are you using?  This EQ has a switch for AI and non AI HU's.  If used with an Alpine AI net unit.  The EQ and the HU will loose certain functions because it will be control by the other unit (either HU or EQ not both).  But power isn't one of these.
Do it right the first time
