02 Suburban/Tahoe factory re-arm
01 Suburban LS
Member - Posts: 43
Posted: May 13, 2005 at 12:30 PM / IP Logged
Where is, if there is one, the factory re-arm wire in the BCM? The Crimestopper remote start I installed in my parents Tahoe has outputs for factory disarm and rearm. I got the disarm done as well as everything else. Just wondering on this one last thing.
mxxmikexx
Silver - Posts: 796
Posted: May 13, 2005 at 7:12 PM / IP Logged
the factory alarm simply arms when you lock the doors, to the best of my knowledge there is no "re-arm"
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
KarTuneMan
Platinum - Posts: 7,056
Posted: May 14, 2005 at 1:41 AM / IP Logged
Correct!
shesaidshewas18
Copper - Posts: 96
Posted: May 14, 2005 at 3:15 AM / IP Logged
Just arm the car with the Crimestopper remote, and check to see if the "Security" light comes and flashes in the dash gauges. If it doesnt, then I *think* you have to have the door open, and then lock it.
01 Suburban LS
Member - Posts: 43
Posted: May 14, 2005 at 9:16 AM / IP Logged
I'll check into your suggestions, thanks...
-Mike
mxxmikexx
Silver - Posts: 796
Posted: May 14, 2005 at 4:52 PM / IP Logged
"Just arm the car with the Crimestopper remote, and check to see if the "Security" light comes and flashes in the dash gauges. If it doesnt, then I *think* you have to have the door open, and then lock it."
i believe that statement is correct, if you lock the vehicle with the new system, the fact. alarm will not arm unless you lock it with the door open and then shut it.
Mike Battaglia
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
