Tach vs Voltage Sense vs crank time
blazo
Member - Posts: 13
Posted: November 24, 2002 at 8:54 AM / IP Logged
odviously, tach is gonna be the most reiable for remote starts, and crank time is the least reliable. but i've never used voltage sensing. i read up on it, and it looks like it would start the car pretty consistantly. Where i work, i get paid for commision, so the more cars i do, the more money i make. but i'm also not a "hack" so i run tach, even though it takes a little extra time going through the firewall, and is sometimes hard to find. if you have used voltage sense, what was your experience with it, does it work conistantly. do customers come back? would u use it on u'r own car? any input would be appricated. thanks.
Frank
MECP 1st class installer.
Moderator - Posts: 12,488
Posted: November 24, 2002 at 9:11 AM / IP Logged
Alternator sense is my last resort when I can't find a consistant or clean signal from the tach wire or injector. The only reason why the tach is so popular with installers is because most units on the market do not come with a voltage sensing circuit in order for the alternator sense to work. I have only had one vehicle that I had to use the alternator sense option on and it was a Plymouth Laser ( 1992 Turbo ). This car defied all logic when it comes to car manufacturing. Normal 4 cylinder with turbo, but all injector wires were different, had a wierd tach filter wire attachment on it and it only gave AC voltage under 1 volt for that tach wire. So the only thing was to use the alternator sense and it hasn't come back yet. The only problem with this method is that you have to find the wire that test properly with this procedure. Target wire should rest between 0-6 volts with engine off and rises to 12 volts or more when started.
blazo
Member - Posts: 13
Posted: November 24, 2002 at 9:34 AM / IP Logged
what i'm talking about is a dei unit, that has voltage sense to see if the car has started. there's no wire hookup, it senses through the constant power source that it is hooked to. i think that it works with crank time to see if the car has started or not. but i'm not sure if it works well. (the voltage sense settings are low or high). the dei tech site says that it senses voltage right before cranking, then right after cranking. because generaly a cars electrical system is 14volts while the moter is running, and 12 or less when it isnt. i guess my question is is it a 3rd way to do a remote start, or is it just a way to see if the car is running using crank time?
Frank
Chris Luongo
Platinum - Posts: 3,746
Posted: November 24, 2002 at 6:58 PM / IP Logged
The DEI's instructions are lousy.  Here is how the three different modes work:
1.  Tach.  Like we expect, when the unit senses a certain RPM has been reached, it stops cranking the starter.
2.  Voltage sense.  The unit cranks the starter for a FIXED amount of time---default is 0.6 seconds, but you can adjust it.  If the unit "sees" the car's voltage rise, it realizes the engine is running, and therefore keeps the ignition alive.  If the voltage does not rise, the unit shuts the car off and tries again.
3.  I forget the name of this mode, but it says "sensing off" or something like that.  The unit cranks the starter for a fixed amount of time---again, 0.6 seconds default, and then makes no attempt to monitor the tach OR the voltage.  It simply assumes the engine has started, and leaves the ignition powered up for the next 12 or 24 minutes.
So, even in voltage sense, the starter still cranks for that fixed amount of time.  In my opinion, no matter how you adjust it, it's going to either overcrank in the summer, or undercrank in the winter.  Undercranking will bring the customer back for sure, since the car won't successfully remote start.  Most customers aren't likely to notice overcranking at all, but I'd imagine it's not very good for the starter.
Of course, a newer car that runs perfectly, is likely to require about the same cranking time whether cold or warm---you might well get away with voltage sense.  If the car's old and junky and needs a tuneup to begin with, I'd try really hard to find a tach wire someplace.
Another tip:  Don't forget that these various modes can also be useful troubleshooting tools.  If you're having a difficult time getting your install to work properly, you might consider temporarily turning all sensing off, so you can more easily identify and fix any of the other things you did wrong.
dcash18
Member - Posts: 38
Posted: November 24, 2002 at 8:33 PM / IP Logged
The section is called engine checking Chris, and i agree with your evaluation
blazo
Member - Posts: 13
Posted: November 27, 2002 at 10:11 PM / IP Logged
thanx guys, i'll keep that in mind
Frank
