What now after big three upgrade?
Reeceddogg
Copper - Posts: 329
Posted: October 05, 2005 at 11:38 PM / IP Logged
i have done the big three upgrade and my voltage is still droping below 12 volts to around 10.3 when the bass hits. i hae two rockford 800a2 pushing a pioneer premier ts-w5000spl. and i plan on getting the (2)directed 2400d and another spl. any ideas
rallysport
Copper - Posts: 172
Posted: October 06, 2005 at 12:46 AM / IP Logged
sounds like you need a high output alternator
alpine_king
Copper - Posts: 73
Posted: October 06, 2005 at 8:06 PM / IP Logged
try a optima battery too, run about 185 bucks.
1993 Ford Ranger.
Head Unit.Alpine CDA-9831
Front Speakers.Infinity 6010 Reference Series
Amp.Alpine MRD-M1005
Subs.3 Kicker CVR10
Rear Speakers.SPL CS-573
20" Boss 312's, lowered 3/4
KarTuneMan
Platinum - Posts: 7,056
Posted: October 06, 2005 at 8:32 PM / IP Logged
It takes power to make power......I would suggest, first getting a new H.O. alt.  When you can "make" the power, then you need to be able to store it, and recover it....
Look for Kinetik power cells, not optima batteries. Kinetik will give you more storage in a smaller package with quicker discharge and recharge!
forbidden
Platinum - Posts: 5,352
Posted: October 06, 2005 at 8:52 PM / IP Logged
Did you check the return resistance reading on your ground?
ssnds
Copper - Posts: 169
Posted: October 06, 2005 at 9:07 PM / IP Logged
would getting like a 10farad cell help? or would u still need a H.O. alt. for that too?
SSounds
DYohn
Moderator - Posts: 10,741
Posted: October 06, 2005 at 9:10 PM / IP Logged
A cap will only make things worse.  Capacitors are useful to help maintain amplifier output but only after you have sufficient power to begin with.  HO Alt is what you need.
forbidden
Posted: October 06, 2005 at 9:11 PM / IP Logged
No, a cap does not create power, it uses and stores it. If your voltage is being sapped out this much, a cap is only going to compound the issue.
Drewt
Copper - Posts: 183
Posted: October 06, 2005 at 9:37 PM / IP Logged
you'll probally need a new battery and a HO alt. Just get a marine battery of decent quality. Optima batteries aren't any better unless you're gonna run a rock crawler or something that may flip over...
-Drew
Reeceddogg
Copper - Posts: 329
Posted: October 07, 2005 at 10:23 AM / IP Logged
Any thoughts on using a marine battery. i had considered this in the past but didn't know if it would work. i know better than to get a regular capacitor, but i was considering one of the batcaps, i can get a 400 farad for around 100 dollars
