VSS Wire for BMW 325i
Jimmy 2 Times
Copper - Posts: 67
Posted: December 31, 2005 at 7:02 PM / IP Logged
I am looking for the VSS wire for a 2001 BMW 325i.  I have searched on direct techs, and it says it is the (BLACK/ white wire on the 10 plug radio harness)  I looked at the wires in the 10 pin harness, and there is NO BLACK/ white wire.  This car does not have the harmon cardon system installed it it.
Can someone help me out here. Is there another place where i can look for this wire? And how exactly do you test for a VSS wire?
thanks in advance
hitec
Member - Posts: 25
Posted: January 07, 2006 at 11:27 PM / IP Logged
Hi Jimmy 2times. Vss (vehicle speed sensor) located in the transmission ,start from there you will find the wire.you also need a volt meter to check the resistance (ohm) of it.
Hitec
n2 salas
Posted: January 12, 2006 at 8:59 AM / IP Logged
Use a soundgate CANPALS2 and get the can wires behind the cluster they are
the onlty twisted pair, yellow/red is high and yellow/brown is low.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
