Need for an External Starter Kill Relay?
gyropilot
Member - Posts: 14
Posted: February 09, 2006 at 11:32 PM / IP Logged
I'm installing a Clarion Ungo SR6000 remote start / alarm this weekend.  It's made by DEI for Clarion and is identical to the Viper 791XV, complete with a satellite relay pack for the starter, ignition, and accessory circuits.  The satellite relay pack is connected to the main alarm unit via a ribbon cable.
The install manual also explains that once the satellite relay pack is wired to the vehicle, it essentially takes over the function of controlling the starter... the ignition key no longer sends current directly to the starter.  So obviously when the ignition key is turned, it's requesting the satellite relay pack to energize the starter.
The manual further states that anti-grind protection is provided by the satellite relay pack (it can be disabled if desired).
I'm a little confused about whether or not I need an external starter kill relay for this system.  The main unit of the alarm system has a standard orange ground-when-armed wire, and the install manual mentions it's used for an "optional" starter kill relay if desired.
it would seem to me that since the satellite relay pack is controlling the starter, *surely* it wouldn't energize the starter via the ignition key (or by trying to hot wire the vehicle) if the alarm system where armed... right?  Neither the owner's or install manual specifically state one way or the other.
If it won't allow the starter to be energized when the alarm is armed, there's no need to add an external starter kill relay to such a system because that would be duplication... correct?
Any of you professional Viper 791 installers know one way or the other?
Thanks in advance,
John L.
97f150ext
Copper - Posts: 104
Posted: February 10, 2006 at 9:25 AM / IP Logged
you wont need an external starter kill, its built in to that relay pack.  there are two starter wires on that pack.  cut the starter wire and one wire goes key side and the other goes starter side.  then whenever you lock (arm) the system, the starter wire in interupted thus giving you starter kill.
Geeque
Silver - Posts: 310
Posted: February 10, 2006 at 9:28 AM / IP Logged
I think the green wire from relay pacy goes to key side and purple from relay pack goes to starter side.
Gary Kline
MECP Master Technician
catalin capota
Copper - Posts: 74
Posted: February 10, 2006 at 10:40 AM / IP Logged
That starter kill is also useful for anti-grinding when remotely started.
gyropilot
Member - Posts: 14
Posted: February 10, 2006 at 11:40 AM / IP Logged
Thanks for the info everyone... I really appreciate the quick responses.
Have a great weekend,
John L.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
