Eclipse deck, memory stick?
killer sonata
Silver - Posts: 718
Posted: June 06, 2006 at 8:13 PM / IP Logged
You bet I do! lol. I believe the book says that the HU needs to be in standby mode. Did you ensure this? It took me a while to figure it out but what they mean by standby mode is when the car is on but you have pressed the power button on the deck so only the clock is displayed. I forget off hand what the other directions are, but if you follow the book you should be good from here. Let me know if you ahve any other problems.
"People with mullets live 40% longer"   - Ricky Bobby
haemphyst
Platinum - Posts: 5,054
Posted: June 07, 2006 at 8:49 AM / IP Logged
Yep... made sure it was in standby mode... I can set the security with a CD, no problem, so I am pretty certain I know what standby mode is... You have to do that from standby, too, right?
After that, it is "Button 1", plus "Function Button", hold for more than 2 seconds. That no workie. Tried "Function Button" plus "Button 1", hold. That no workie. "Function Button" plus "Button 6", hold. Asks (correctly) to insert security CD. I can cancel Security CD in the same way. I don't know from here. Any suggestions from the Eclipse dealers lurking about?
killer sonata
Silver - Posts: 718
Posted: June 10, 2006 at 9:17 PM / IP Logged
I think you are trying to follow the wrong directions. There are 2 different securities you can do with the memory stick. The first being if the deck is desconnected and loses power, when its reconnected you have to enter the correct PIN to coincide with the MS. The second, if I remember right, has something to do with the ignition of the vehicle. I forget exactly what it is. Ill have to look at my book again because its been a while since Ive done it.
Page of 3
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
