pats or no pats, 2005 dodge dakota
paulr1976
Member - Posts: 9
Posted: October 17, 2006 at 5:07 PM / IP Logged
Hi,
I'm going to be working on a friend's 2005 dodge dakota pick up--for a remote start. How do i tell if the truck has a pats device onboard? This is a pretty basic dakota, no frills except for automatic trans..3.7l v6 4x4. I don't see any indication (i know fords have the 'theft' light. but nothing indicates that is has pats. Thanks in advance. paul
Twelvoltz
Platinum - Posts: 2,384
Posted: October 17, 2006 at 5:30 PM / IP Logged
Search the forums, this question has been answered already in this post..
Mike M2
Platinum - Posts: 2,652
Posted: October 17, 2006 at 5:34 PM / IP Logged
It really hasn't. Bottom line is some do and some don't. I recently did power windows in 2 Dakotas and neither had a transponder key. With that info, i bet it's safe to say a basic no frills Dakota probably won't have it....
Mike M2
Tech Manager
CS Dealer Services
Twelvoltz
Posted: October 17, 2006 at 5:51 PM / IP Logged
Quoted from Chris Luongo's post in that thread
"Just because it has the remote built into the key, doesn't mean it has an anti-theft transponder also........I have not seen a Dakota with a transponder yet.
Look carefully at the dashboard, at all the various warning lights......you will see one that is just a circle, a little smaller than a pencil eraser.
If that doesn't light up when you turn on the ignition, there is no transponder."
swamprat323
Gold - Posts: 1,335
Posted: October 18, 2006 at 11:56 AM / IP Logged
sincer its your friends car take the key apart the chip is on th eboard with the battery make sure that not close to the key hole.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
