2006 Dodge Dakota, Remote Start
mryusef
Posted: October 26, 2006 at 11:07 PM / IP Logged
I am hooking up a remote start on a 2006 dodge dakota. I have the remote start working but can't get the heater to come on. I have at least one accesory wire hooked up because the radio comes on but I can't get the blower to come. Can anyone help.
Twelvoltz
Platinum - Posts: 2,384
Posted: October 27, 2006 at 6:39 AM / IP Logged
According to the sheet, your truck has 4 accessory wires. Two pink / YELLOW wires(probably not needed). One pink/white positive accessory and one purple negative accessory wire.
DIRECTWIRE™ WIRING INFORMATION - DODGE / DAKOTA PICKUP / 2006 / Remote Start
[PRINT THIS PAGE]
12volts red, red, RED / lt. blu (40A ea) +   ignition harness
Starter pink/lt. blue   +   ignition harness
Second Starter N/A
Ignition pink/lt. green   +   ignition harness
Second Ignition pink   +   ignition harness
Third Ignition N/A
Accessory purple (-) and pink/white (+)   -,+ ignition harness
Second Accessory pink / YELLOW (x2)   +   ignition harness
Keysense PURPLE / tan   -   ignition harness
Power Lock PURPLE / dk. green   -   DKP or cluster, gry 16P plug, pin 3
Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor lt. green   5wi DKP or cluster, gry 26P plug, pin 15
Unlock Motor tan/lt. green   5wi DKP or cluster, gry 26P plug, pin 12
Parking Lights+ pink/red (L), WHITE/ orange (R) +   IPM, 20 pin plug, pins 15 and 17
Notes: The IPM (Integrated Power Module) is the fuse/relay box on the driver side fender.
The rear taillight wires run from this location down into a harness that follows the frame rail to the rear of the vehicle.
Parking Lights- pink/red   -   sw. or cluster, gry 16P plug, pin 5
Notes: Parking lights are negative trigger thru a 1130 ohm resistor. MUST use a relay.
Hazards WHITE/ orange   -   sw. or cluster, gry 16P plug, pin 8
Notes: The hazard lights are negative trigger thru a 120 ohm resistor. MUST use a relay.
Turn Signal(L) wht/lt. grn(F), wht/dk. grn(R) +   FCM, 12 pin plg and IPM, 40 pin plg
Notes: The FCM (Front Control Module) is attached to the IPM (Integrated Power Module), which is the fuse/relay box on the driver side fender.
Turn Signal(R) WHITE/ tan (F), WHITE/ orange(R) +   FCM, 12 pin plg and IPM, 40 pin plg
Reverse Light WHITE/ lt. green   +   IPM, 40 pin plug, pin 27
Door Trigger see notes   -   each kick or cluster
Notes: The LF door is purple in the gray 26 pin plug, pin 6. The RF door is PURPLE / white in the white plug, pin 23. The LR door is PURPLE / gray in the gray 26 pin plug, pin 8. The RR door is purple / YELLOW in the white plug, pin 22. Use all four wires and diode isolate each.
Dome Supervision yellow/orange   +   cluster, white plug, pin 11
Notes: Also found in the passenger A pillar.
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT red   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire WHITE/ lt. blue   +   brake pedal switch
Parking Brake dk. GREEN / WHITE   -   sw. or cluster, gry 26P plug, pin 3
Horn Trigger dk. GREEN/ purple   -   sw. or cluster, gry 26P plug, pin 10
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 556CW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on the SLT E Package and Laramie models.
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Saturday, May 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
