1997 silverado remote start upgrade
soultinter
Copper - Posts: 170
Posted: December 16, 2006 at 9:01 AM / IP Logged
SCYTEK       very reliable, reasonable price, awesome tachless.    But I also second the audiovox, just harder to install
franka
Member - Posts: 39
Posted: December 18, 2006 at 7:38 AM / IP Logged
Do any of you recognize the unit pictured by me earlier. I cannot figure what it is i was thinking it might be an audiovox product from way back but my 4 button remote has Alta Mere on it. any ideas?
Plan Ahead
franka
Member - Posts: 39
Posted: December 18, 2006 at 12:31 PM / IP Logged
The layout in the main plug look like this:
white= parking light +12V
Red=    +12v input
Brown= Dome light -12V
Orange= Starter kill -12V
Gray=   Trunk Release -12V
Green= Third channel out -12V
Blue=   Horn Flashing -12V
Violet= Pass door unlock -12V
Yellow= Switched 12V acc
plugs 1 (2) pin labeled led
      1 (2) pin labeled switch
      1 (3) pin labeled Unlock,12V,Lock
The first 2 plugs listed are not used
Plan Ahead
franka
Member - Posts: 39
Posted: December 21, 2006 at 2:20 PM / IP Logged
I bought a Galaxy5000 RS-2W on ebay to use for my remote start device on my 97 chevy truck if anyone has any knowlege of tricks for or problems with this Galaxy please advise.
Plan Ahead
ers1121
Copper - Posts: 110
Posted: December 22, 2006 at 6:14 PM / IP Logged
Omega Max-E on ebay about 110.00 great system, mine has been flawless for three years. Another thing to think about with an add-on unit is range. If u use the remots from the keyless entry the range is too short. If the unit you want is from JC Whitney it is probably a Bulldog, ok but not the greatest. Spend a few dollars more and buy a good quality system.
Ed
Ed
franka
Member - Posts: 39
Posted: December 26, 2006 at 6:17 PM / IP Logged
The unit I purchased is a galaxy2000RS-2W I am checking into the additional parts I will need (if any) since the 97 chevy truck already had an aftermarket R/E system there are relays for the door locks already wired in But I am not sure if it is (-) or (+) pulse.
Plan Ahead
franka
Member - Posts: 39
Posted: January 02, 2007 at 12:23 PM / IP Logged
I need to know if I will need a bypass for passlock I or II for my installation? Sorry to be so unknowlegable but I want to be sure about the required work and needed parts before I start.
currently I have the R/S 2000RS-2W and existing relays in place for the locks, but no passlock I or II bypass.
Plan Ahead
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
