reverse polarity, 95 ram pickup
oakley2000sel
Member - Posts: 33
Posted: December 18, 2006 at 10:11 PM / IP Logged
oakley2000sel wrote:
Ok I tried again tonight. I found the wire in the kick and tried it from there and the same result. There is a post in here from some guy that had the same problem exactly but it ended with no resolution. When I hook #87 and #85 or #86 and #87  to 12 volts contant the #87a shows 12 volts constant. As soon as I connect the switch side wire it blows the fuse. I tried hooking everything up without hooking up the factory switch and when I touch negative to #85 at the same time I also tested the ORANGE / purple wire right at the lock and it showed the 12volts but nothing happened! I have no idea what do do at this point. please help.
Here is the post from the other guy that had the same problem. https://www.the12volt.com/installbay/forum_posts.asp?tid=7758&KW=ram+locks
oakley2000sel
Member - Posts: 33
Posted: December 21, 2006 at 7:16 AM / IP Logged
Ok....So after not getting a response I went down to a shop here that installs r/s. They said I had the wrong relays. After all that! I was using 30amp auto relays which it shows in the diagram here. I had no idea there are 2 different types. 1 shows hot on 87a and 1 doesn't. Hooked them up and I was on my way!
