2001 Hyundai Sonata Wiring Guide
Welcome Guest :)
deadride
Member -
Posted: January 09, 2007 at 2:40 PM / IP Logged
I need the wiring guide for this car and where to find the hood pin wire and the tach wire. Thanks.
~Bill
KarTuneMan
Platinum -
Posted: January 11, 2007 at 9:41 AM / IP Logged
Wire/Function | Colour | Location/Description | Polarity |
12 VOLTS | Red | Ignition switch harness | + |
IGNITION | Pink | Ignition switch harness | + |
ACCESSORY | Orange | Ignition switch harness | + |
STARTER | Yellow | Ignition switch harness | + |
KEY SENSE | Lt.green | At chime module on right of column | - |
TACH SIGNAL | See notes | Behind dash dimmer switch | AC |
| | White or Gray plug is located above dimmer switch. Use the WHITE/ BLACK DASHES not the WHITE/ black. |
FUEL INJECTOR | Opposite from Pink | At injector rail on engine | AC |
LOCK | White | In driver's kickpanel | - |
UNLOCK | Blue | In driver's kickpanel | - |
DOORPIN | Yellow | On junction block above DKP | - |
HOODPIN | Lt.blue | On junction block above DKP | - |
| | This wire is only present on models equipped with factory security. |
TRUNK PIN | GREEN/ black | On junction block or in DKP | - |
TRUNK RELEASE | Manual release | | |
FACTORY DISARM | Lt.GREEN/ black | On junction block above DKP | - |
BRAKESWITCH | Blue | At switch above brake pedal | + |
PARKLIGHTS | BROWN / white | In driver's kickpanel | + |
| | VERY IMPORTANT: There are 2 BROWN / WHITE wires in the kickpanel that test as parklight wires. Use the larger of the 2 wires, the smaller wire will blow a fuse if power is applied to it. |
KarTuneMan
Platinum -
Posted: January 11, 2007 at 9:42 AM / IP Logged
HAND BRAKE | Lt.blue | At switch on handbrake lever | - |
HORN | Yellow | At steering column | - |
CLUTCH SWITCH | Green | At switch above clutch pedal | TYPE 1 |
DRIVER WINDOW UP | Blue | At main switch in driver's door | REV POL |
DRIVER WINDOW DOWN | Brown | At main switch in driver's door | REV POL |
PASSENGER WINDOW UP | Lt.blue | At main switch in driver's door | REV POL |
PASSENGER WINDOW DOWN | Tan | At main switch in driver's door | REV POL |
HEADLIGHTS | White | At light switch harness | - |
REVERSE LIGHTS | RED / green or RED / white | Large harness in DKP | + |
VSS WIRE | Brown | At data connector under left dash | |
KarTuneMan
Platinum -
Posted: January 11, 2007 at 9:43 AM / IP Logged
KarTuneMan
Platinum -
Saturday, April 27, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
