2003 Nissan Sentra, Remote Start Wiring
Welcome Guest :)
chiarlanza
Member -
Posted: January 21, 2007 at 12:26 PM / IP Logged
Looking for the specs to install a remote start on an 03 Nissan Sentra.
KarTuneMan
Platinum -
Posted: January 24, 2007 at 8:16 AM / IP Logged
PART | COLOR | LOCATION |
12 VOLT CONSTANT | WHITE/ RED (+) | IGNITION SWITCH HARNESS |
STARTER | BLACK/ WHITE (+) See NOTE *1 | IGNITION SWITCH HARNESS |
STARTER 2 | BLACK / YELLOW (+) See NOTE *1 | IGNITION SWITCH HARNESS |
IGNITION 1 | BLACK/ RED (+) | IGNITION SWITCH HARNESS |
IGNITION 2 | N/A | |
IGNITION 3 | N/A | |
ACCESSORY /HEATER BLOWER 1 | WHITE (+) | IGNITION SWITCH HARNESS |
ACCESSORY /HEATER BLOWER 2 | WHITE/ BLUE (+) | IGNITION SWITCH HARNESS |
KEYSENSE | N/A | |
PARKING LIGHTS ( - ) | N/A | |
PARKING LIGHTS ( + ) | WHITE/ RED (+) or RED / BLUE (+) | IN DRIVERS KICK PANEL or HEADLIGHT SWITCH |
POWER LOCK | GRAY (TYPE B) | @ SECU, See NOTE *2 |
POWER UNLOCK | PURPLE / RED (TYPE B) | @ SECU, See NOTE *2 |
DOOR TRIGGER | See NOTE *3 | @ SECU, See NOTE *2 |
DOMELIGHT SUPERVISION | RED / YELLOW (-) | @ SECU, PIN 8, See NOTE *2 |
TRUNK RELEASE | RED (-) | @ HATCH RELEASE SWITCH |
SLIDING POWER DOOR | N/A | |
HORN | WHITE/ GREEN (-) | @ STEERING COLUMN HARNESS |
TACH | ANY WIRE BLACK/ RED, PURPLE, BLUE/RED or GRAY/RED | @ ANY IGNITION COIL |
WAIT TO START LIGHT | N/A | |
BRAKE | RED / GREEN (+) | @ SWITCH ABOVE BRAKE PEDAL |
FACTORY ALARM DISARM | WHITE/ BLUE(-) | @ SECU, PIN 30, See NOTE *2 |
ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER |
EXTRA INFORMATION |
NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold. NOTE *2 THE SECU (Security Electronic Control Unit) IS LOCATED TO THE RIGHT OF STEERING COLUMN. NOTE *3 ON VEHICLES WITHOUT POWER DOORLOCKS USE RED / WHITE (-) IN DRIVERS KICK PANEL. ON VEHICLES WITH POWER DOORLOCKS, USE RED (-) FOR DRIVERS DOOR AND RED / WHITE (-) FOR PASSENGER DOOR, WHEN CONNECTING TO AN ALARM SYSTEM USE BOTH DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, See DIAGRAM |
Sunday, April 28, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
