Alpine SEC-100 Unlocking Issues
starskie75
Posted: February 10, 2003 at 5:37 PM / IP Logged
Has anyone had intermittent issues with the Alpine SEC-100 not always unlocking the doors when disarming?  Once out of every four disarms the doors will not unlock.  Would reprogramming the system cure this issue?
GMC4x4Guy
Copper - Posts: 117
Posted: February 10, 2003 at 8:54 PM / IP Logged
My friend installed the exact same alarm and is having the exact same problem. I've tried everything to fix it and still no luck. The next step is a different alarm.
"Drive it like you stole it"
Player69
Silver - Posts: 504
Posted: February 10, 2003 at 9:10 PM / IP Logged
Just out of curiousity what kind of car is this in?  Does the car by chance have - locks and you are not using relays?  Just a thought maybe try adding a relay if this is the case.  If not, please ignore me. Alpine SEC-100 Unlocking Issues - Last Post -- posted image.
Moderator - Posts: 12,488
Posted: February 11, 2003 at 6:52 AM / IP Logged
I agree with Player69......... add a relay to the system and see if the issue continues.
starskie75
Posted: February 11, 2003 at 9:22 AM / IP Logged
Thanks for the follow up.
The system is installed in a 2001 Toyota Tacoma with all power options.  In addition, the range of the alarm is very poor especially if parked near other vehicles.
Posted: February 11, 2003 at 12:21 PM / IP Logged
Make sure you position the antenna outside of the blue tinted area above the rear view mirror.
10nesne1
Silver - Posts: 284
Posted: February 11, 2003 at 6:48 PM / IP Logged
You can add relays if you want, but you don't need to.  You will have to hook up a couple diodes to isolate the child safety unlock.  Here is a diagram.
michaelodeon0
Posted: March 20, 2003 at 3:46 PM / IP Logged
Its funny, i had the same alarm and the same kind of car and the exact same problem (funny how that works out) Did you ever resolve this issue. Also could the child safety lock issue be the cause even if its a 2 door? Do we know for sure wether its the car or the alarm?
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
