99 dodge ram 5 wire
d&v car audio
Member - Posts: 10
Posted: June 05, 2007 at 9:55 AM / IP Logged
I got a dodge ram 1999 coming in for a keyless system install.  I have looked at other post on this site and I don't unstand what going on. sorry but I'm new to the alarm install game.
I have a double relay socket and the wire info below.  it does not have a listing for passenger lock... but it has door lock and drivers lock.. so my question is how do I wire a 5 wire relay to the wires listed below?
1999 Dodge Ram Pickup Security Information
Constant 12V+Pink/Black or Red Ignition Switch Harness
StarterYellow or Blue / YELLOW Ignition Switch Harness, Must Add Relay for Remote Start
IgnitionDark Blue Ignition Switch Harness
Ignition 2BLACK/ White Ignition Switch Harness
AccessoryBLACK/ Orange Ignition Switch Harness (Heat/AC)
TachBLACK/ Gray PCM Passenger's Rear of Engine on Firewall
Neutral Safety WireBLACK/ White (-) Ignition Switch Harness
Brake SwitchWHITE/ Tan Brake Switch or Ignition Switch Harness
Trunk Pinn/a
Parking LightsBLACK / YELLOW (+) Driver's Kick Panel White Connector Driver's Kick Panel
Head LampLight GREEN/ Black Steering Column
Factory DisarmLight GREEN/ Orange (-) 24 Pin Connector behind Driver's Dash
Door TriggerYellow (-) Driver's Kick Panel White Connector Driver's Kick
Door LockORANGE / Purple (REV) 10 Pin Connector Driver's Kick Panel Reverse Polarity
Door UnlockPink/Purple Driver's Kick Panel
Driver's LockORANGE / Black Left Kick Panel
Driver's UnlockPink/Black Left Kick Panel
Passenger UnlockPink/Purple Left Kick Panel
Horn WireBLACK/ Red (-) 74 Pin Connector behind Driver's Dash
Windows UpLF=Light Blue, RF=BROWN / White
Windows DownLF=White, RF=PURPLE / White
If your not living on the edge, your taking up too much space.
KarTuneMan
Platinum - Posts: 7,056
Posted: June 05, 2007 at 12:48 PM / IP Logged
They all lock at the same time with one push of 1 button. There is no reason to lock one door at a time.
Unlock is a different thing. You might want to do just the drivers door, then another push you unlock the pass. door.
d&v car audio
Member - Posts: 10
Posted: June 05, 2007 at 1:43 PM / IP Logged
I will need to use the 5 wire for reverse polarity right?  if so does the  alarm lock output, alarm unlock output come from the alarm or is it the output from the relay to the alarm?
99 dodge ram 5 wire - Last Post -- posted image. 5 Wire Alternating 12 Volts Positive Door Locks
Like the configuration above, the switch, when moved in either direction, applies both power and ground directly to motor legs  without the use of any relays. Except, at the switch in this case, both motor legs rest at ground . Therefore it is only necessary to change the polarity of one motor leg to lock or unlock the vehicle.
99 dodge ram 5 wire - Last Post -- posted image. Actuators / Reverse Polarity
This is practically identical to the 5 wire alternating 12V(+) system above. The only difference is there's no switch! Both motor legs rest at ground at the relays. To lock or unlock the vehicle, polarity is changed on one motor leg.
KarTuneMan
Posted: June 05, 2007 at 4:13 PM / IP Logged
The top diagram is the one to follow. See the blue and green that says 'to alarm outputs" These are your lock and unlock out from the alarm to trigger your relays.
d&v car audio
Member - Posts: 10
Posted: June 05, 2007 at 4:32 PM / IP Logged
ok do I not use the wire below
KarTuneMan
Posted: June 05, 2007 at 7:17 PM / IP Logged
 LOCK ORANGE / purple In driver's kickpanel   Rev Pol
 UNLOCK Pink/purple In driver's kickpanel   Rev Pol
Use these and wire like the top diagram.
d&v car audio
Member - Posts: 10
Posted: June 05, 2007 at 9:35 PM / IP Logged
Thanks you have been a big help.
project_86
Member - Posts: 17
Posted: June 06, 2007 at 4:08 PM / IP Logged
some of them,  pretty sure 98's have  5wire unlock and negative trigger thru resistance lock,  kinda never know what is going to be in there sometimes in those.  where did you get those notes from?
d&v car audio
Member - Posts: 10
Posted: June 07, 2007 at 6:04 AM / IP Logged
this website
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
