08 scion xb alarm schematic
nava94
Silver - Posts: 296
Posted: November 01, 2007 at 8:47 PM / IP Logged
hey guys have a 2008 scion xb that i'm doing a viper 791 alarm remote start does anyone have a schematic for this lil bad boy?thanks in advance.
Twelvoltz
Platinum - Posts: 2,384
Posted: November 01, 2007 at 9:00 PM / IP Logged
Audiovox lists:
          #513391: 2008 SCION XB 4DR SUV
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          LIGHT GREEN          (+)          RADIO HARNESS
     Accesory          GRAY          (+)          RADIO HARNESS
     Ground          BROWN          (-)          RADIO HARNESS
     Illumination          GREEN          (+)          AT RADIO HARNESS
     Power Antenna          ORANGE          (+)          RADIO HARNESS
     LF Speaker (+)          PINK
     LF Speaker (-)          VIOLET
     RF Speaker (+)          LIGHT GREEN
     RF Speaker (-)          BLUE
     LR Speaker (+)          BLACK
     LR Speaker (-)          YELLOW
     RR Speaker (+)          RED
     RR Speaker (-)          WHITE
     Steering Cntrls          OPTIONAL
     Speed Cntrl          OPTIONAL
     Radio Security          YES
     Security
     Battery          WHITE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          GRAY          (+)          IGNITION SWITCH HARNESS
     Starter 1          WHITE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger
               USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE
     Domelight Super          WHITE          (-)          AT VEHICLE FUSEBOX
     LF Latch          WHITE          (-)          IN PLUG AT VEHICLE FUSEBOX
     RF Latch          BROWN          (-)          IN PLUG AT VEHICLE FUSEBOX
     LR Latch          LIGHT BLUE          (-)          IN HARNESS IN DRIVER KICKPANEL
     RR Latch          LIGHT GREEN          (-)          IN PLUG AT VEHICLE FUSEBOX
     Trunk Trigger          LIGHT GREEN          (-)          AT VEHICLE FUSEBOX
     Parking Lights          GREEN          (+)          AT VEHICLE FUSEBOX
     Convenience
     Headlights-Lo          GRAY          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Headlights-Hi          PINK          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     LF Pk Lt Bulb          GREEN          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          GREEN          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          GREEN          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          GREEN          (+)          AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights          GRAY          (-)          AT VEHICLE HAZARD LIGHT SWITCH
     LF Hazrd Bulb          YELLOW          (+)          AT FRONT LEFT TURNSIGNAL BULB
     RF Hazrd Bulb          BLUE/RED          (+)          AT FRONT RIGHT TURNSIGNAL BULB
     LR Hazrd Bulb          YELLOW          (+)          AT TAIL LIGHT ASSEMBLY
     RR Hazrd Bulb          LIGHT BLUE          (+)          AT TAIL LIGHT ASSEMBLY
     Wipers-Lo          BLACK          (+)          AT VEHICLE WIPER CONTROL SWITCH
     Wipers-Hi          RED          (+)          IGNITION SWITCH HARNESS
     Parking Brake          BLACK          (-)          AT PARKING BRAKE SWITCH
     Trnk Release          ORANGE          (-)          IN HARNESS IN DRIVER KICKPANEL
     Remote Start
     Ignition 2          WHITE          (+)          IGNITION SWITCH HARNESS
     Accessory 1          BLACK          (+)          IGNITION SWITCH HARNESS
     Starter 2          WHITE          (+)          IGNITION SWITCH HARNESS
     Key Sense          BLUE          (-)          AT VEHICLE FUSE BOX
               THIS WIRE WILL DISARM THE FACTORY ALARM WITHOUT UNLOCKING THE DOORS
     Tachometer          GRAY          (AC)          AT DATA LINK CONNECTOR
     Crankshaft Sensor          ORANGE          (AC)          AT ECM MODULE BEHIND GLOVEBOX
     Camshaft Sensor          BLACK          (AC)          AT ECM MODULE BEHIND GLOVEBOX
     Speed Sense          VIOLET          (AC)          AT RADIO HARNESS
               ALSO AT ECU MODULE PIN A8
     Brake Lights          BLUE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED          (+)          AT INTERIOR FUSE BOX - TOP LEFT CORNER
     Horn          LIGHT GREEN          (-)          IGNITION SWITCH HARNESS
               ALSO AT VEHICLE FUSEBOX
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          PINK          (-)          IN HARNESS IN DRIVER KICKPANEL
               THIS WIRE REQUIRES A DOUBLE PULSE
     PowerLock          LIGHT BLUE          (-)          IN HARNESS IN DRIVER KICKPANEL
     Driver Mtr Unlock          LIGHT BLUE          (AC)          AT DRIVER DOOR LOCK MOTOR
     Driver Mtr Lock          RED          (AC)          AT DRIVER DOOR LOCK MOTOR
     Pas Mtr Unlock          LIGHT BLUE          (AC)          AT PASSENGER DOOR LOCK MOTOR
     Pas Mtr Lock          RED          (AC)          AT PASSENGER DOOR LOCK MOTOR
     LF Window Up          PINK          (REV)          AT DRIVER WINDOW SWITCH
     LF Window Dn          WHITE          (REV)          AT DRIVER WINDOW SWITCH
     RF Window Up          GREEN          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RF Window Dn          BROWN          (REV)          AIN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Up          RED          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Dn          BLUE          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Up          GREEN          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Dn          BROWN          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Reeceddogg
Copper - Posts: 329
Posted: February 10, 2008 at 2:18 PM / IP Logged
Does this car have any factory immobilizers
tonyberg
Copper - Posts: 116
Posted: February 10, 2008 at 4:14 PM / IP Logged
no
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
