blinking led without alarm
dogthenine
Member - Posts: 8
Posted: November 13, 2007 at 5:17 PM / IP Logged
Hello,
I have a 99 Durango with keyless entry and no alarm. I am wanting to wire a blinking led into my dash. I want it to start blinking when the doors are locked using the remote, and stop when they are unlocked. What supplies do I need, and how do I wire it up (diagram)?
Thanks in Advanced,
dogthenine
techman93
Silver - Posts: 591
Posted: November 13, 2007 at 9:17 PM / IP Logged
Radio Shack sell blinking LED's with a built in resistor you can wire to 12v+. You can set it to go on when you shut ignition off and off when the car is running through a relay. Wire 12v+ to pin 30, to the LED positive side from pin 87a. Pin 86 to ground and 85 to ignition 12v+. You don't need to connect anything to pin 87. That would be the easiest way to add a blinking light for theft deterrence.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
dogthenine
Member - Posts: 8
Posted: November 13, 2007 at 9:35 PM / IP Logged
I can do that without a relay. One side with resistor to constant 12+, and the other to an accessory 12+. But that's not what I want to do.
I want the led to start blinking when the doors are locked (not when the ignition is off), and turn off when the doors are unlocked (with out the ingnition having to be on.)
techman93
Silver - Posts: 591
Posted: November 14, 2007 at 7:44 AM / IP Logged
You may need a low voltage trigger or a channel creator to create a latched output using the lock button. Then shut off when you unlock.
dogthenine
Member - Posts: 8
Posted: November 16, 2007 at 8:28 AM / IP Logged
How do I do that?
stangbanger242
Member - Posts: 19
Posted: December 02, 2007 at 8:43 PM / IP Logged
Hey,
Are you still lookin for a dia gram to wire up this led the way u want?
To be honest, it will be easier to do it the way techman said in his first post. Although it can be done with relays, it will take way more time and patience then needed.
ive got a relay diagram for the way you want it. let me know
Support the TROOPS!!
dogthenine
Member - Posts: 8
Posted: December 02, 2007 at 9:22 PM / IP Logged
stangbanger242 wrote:
Hey,
Yes, Thanks!
Platinum - Posts: 13,667
Posted: December 02, 2007 at 9:29 PM / IP Logged
A 12 Volt flashing LED from Radio shack    A magnetic alarrm switch also available from Radio Shack.   You will have to mount the Switch somehow and attach the Magnet to the Door Lock rod so when the door is locked it will trip the switch.  You will need to use the Normally Open contacts of the switch.  No relays and No extra current draw.  Just the LED current, and that will be minimal.
stangbanger242
Member - Posts: 19
Posted: December 02, 2007 at 10:54 PM / IP Logged
How many wires are there going to your lock motor?
dogthenine
Member - Posts: 8
Posted: December 02, 2007 at 11:53 PM / IP Logged
The actuator has four wires going to it.
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
