For those with a Wrangler who don't mind losing the back seat, this idea or a variation of it may be for you.
1st we start with covering everything and anything we don't want resin splashed on. IT WILL IF YOU DON'T TAKE PRECAUTIONS.
Hefty 3 ply trashbags work wonders in the vehicle and out as you can cover your work table with them by taping down the edges...make your mess...then wrap it up and toss away. Recover for the next step and so on.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/88D_100_1819.jpg)
Here we taped the entire rear section of our TJ as we are going to cover this entire area with fiberglass.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1821.jpg)
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1823.jpg)
our initial layer on the driver's side completed. Below are both sides removed after curing.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1836.jpg)
another angle.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1837.jpg)
we mock up the borders. Now this step can be done before or after the initial layer. Most prefer making the borders first then lay on the fiberglass so its all attached when done. Problem we found with large areas is warpage causing our wood borders to buckle. So we opted to lay the glass first. Let it warp without the borders. Then run another glassing session with the borders. These borders are what gives your stretchy T-shirt material something to attach to and provide the transition to match the vehicle.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1849.jpg)
I've seen plenty of info on this site pertaining to woofer rings so i won't get into too much detail. Below we "coupled" 2 10 inch Kickers which we will do for both sides of the Jeep for a total of 4 10's.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1848.jpg)
The "skeleton" is mocked up
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1858.jpg)
Jo Ann Fabrics ROCKS! 3 square yards of cotton/poly/acrylic cost me 33 us dollars. It was enough to do this whole project. Fleece works great too but they didn't have any that day.
And for the guys...alot of cute girls work there. You WILL pique their curiosity!
Below we have resin curing after a stretch and HOT MIX!
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1853.jpg)
1 down 1 to go. Be careful when trimming the edges. We used very sharp razors.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1854.jpg)
Both sides are ready for carpet. If we were to paint these, a bit more bodywork would be needed to get the enclosures perfect for painting. We were up against the clock and opted to carpet them.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1862.jpg)
Below you see Tony B exhausted after 47 hours straight into this build. He was hell bent on getting our vehicle to the Pa Jeep show 2 days after this pic was taken. Goal was accomplished and he slept through most of the show.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1870.jpg)
bolting the enclosures and adding the woofers.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1873.jpg)
Carpet and vinyl are a good combo when done in moderation.
![1997 jeep tj, fiberglass -- posted image.](https://www.the12volt.com/installbay/uploads/100_1869.jpg)
Next post we will tackle the front speaker pods for our 1997 JEEP TJ
L x W x H / 1728 = ?
D x 3.14 = C
