factory amp turn on how to test
saleengt
Copper - Posts: 73
Posted: May 26, 2004 at 3:14 AM / IP Logged
does anybody know any tricks to test for this wire?
raydawg357
Silver - Posts: 769
Posted: May 26, 2004 at 8:21 AM / IP Logged
Check it with a DMM.  It should be throwing 12v
Do it right the first time
Thecanadian
Member - Posts: 9
Posted: May 26, 2004 at 8:23 AM / IP Logged
There are no tricks.  Do u mean from a deck - use a volt meter   Or on the amplifier - connect +12v and ground then jump constant 12volts to turn on wire.  The amp power indicator should turn on(assuming it has one).  Make sure jumper to turn on is fuled with low amp fuse, and nothing else is connected to the amplifier for safety.  You should probably do this outside your car with a battery charger or other external source of power(Bench test)  Good luck!
Platinum - Posts: 12,488
Posted: May 26, 2004 at 11:47 AM / IP Logged
Use a light tester or preferrably a DMM for testing this. Turn on your deck and this wire should register 12 volts.
forbidden
Platinum - Posts: 5,354
Posted: May 26, 2004 at 2:18 PM / IP Logged
Some of the amplifiers in Ford vehicles also show 5 volts on the turn on line if memory is correct, maybe a newer Rustang for that matter.
Sweekster
Silver - Posts: 481
Posted: May 26, 2004 at 2:46 PM / IP Logged
'tis true. Premium sound equipped fords and lincolns use 5 volt remote turn on and power antenna.
Duane...
If you think you're confused, imagine how you feel.   factory amp turn on how to test -- posted image.
