a/v system info please...
princestfu
Member - Posts: 24
Posted: January 28, 2003 at 8:07 PM / IP Logged
hi, i have a 95 nissan altima, and currently have a pioneer mp3 HU, mb quartz component system in da front, and sony xplod's in the rear. the speakers are hooked up to a rockford fosgate 80o watt amp. i'm buying a solobaric L7 15" sub and a power acoustic 1200 watt amp. i also wanna add 2 lcd screens on my sun visors wif a tv tuner and a ps2 so i could watch dvds also. i wanna noe wuts da best way to run everything and wut other stuff do i need because i heard that i need sum kinda amplification so i could run signal to the 2 lcd screens. but wut about da audio ? do i use Y rca connectors to run to da amp ? danx for the help.
Moderator - Posts: 12,488
Posted: January 28, 2003 at 11:07 PM / IP Logged
You will need a power converter for the PS2 system and then you will need an FM modulator ( unless your Pioneer deck has audio inputs ) for the sound from the PS2. You will need to hook up the FM modulator RCA's to the amplifier that has your speakers attached to it and use Y adaptors to split the signal into the amplifier. If you are using the Pioneer deck then all you need to do is tie into the RCA inputs if available.
Sunday, November 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
