Ford focus keyless entry problem
edwardoo
Posted: July 07, 2017 at 4:10 PM / IP Logged Link to Post Post Reply Quote edwardoo
Hello to everyone.
I have problem with wiring keyless entry for my focus, the problem is i can't find "power unlock wire" i've test all black/yellow wires and nothing, power lock wire i found behind drivers kick panel under the carpet and its not black/red, mostly like black/orange and locking works fine. What can be the problem ? Here's some pictuers.
Power lock wire location under carpet behind drivers kick panel
Ford focus keyless entry problem -- posted image.
Central locking unit
Passenger kick panel
Drivers kick panel
Keyless entry
And as i said i've tested all Black/Yellow wire from drivers side
I appreciate every help
Thank You..
Platinum - Posts: 13,674
Posted: July 07, 2017 at 5:14 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Year?
edwardoo
Posted: July 07, 2017 at 5:15 PM / IP Logged Link to Post Post Reply Quote edwardoo
2000
Posted: July 07, 2017 at 5:49 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Is it not in the harness that goes into the door at the drivers kick panel?
edwardoo
Posted: July 07, 2017 at 5:52 PM / IP Logged Link to Post Post Reply Quote edwardoo
Heres pictures from door
Posted: July 07, 2017 at 9:27 PM / IP Logged Link to Post Post Reply Quote i am an idiot
There has to be another plug going into the door. Squeeze the boot going from door jamb to the door, and see if you can figure out how many wires are in it.
edwardoo
Posted: July 08, 2017 at 5:20 AM / IP Logged Link to Post Post Reply Quote edwardoo
Wires from door boot
Posted: July 08, 2017 at 3:55 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Do you have a multimeter? If so, set it to dc volts or the 20 volt dc scale. Press and hold the red meter lead to positive voltage somewhere. Then probe each of those wires while having someone unlock the door with the key. When you are on the right wire the meter should read 12 volts while the key is in the unlock position.
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
