Blade-AL Or Similar, 2013-2017 Dodge Viper
occpilot
Posted: March 02, 2024 at 10:50 PM / IP Logged Link to Post Post Reply Quote occpilot
Hello,
I was wondering if anyone has had any luck with doing a non-analog install of a compustar/blade-al on a fifth generation dodge viper 2013-2017? I used the t-harness for a dodge/chrysler and everything connected as it should. The problem is that when I flash the blade-al using a charger/challenger of similar year (CH7), it doesn't recognize the unlock/lock codes. I was hoping that there was a firmware that someone has gotten to work. The BCM seems similar to the other dodge products.
Thank you
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
