Compustar CM6200 vs CM7200?
moparguy98
Member - Posts: 7
Posted: March 12, 2024 at 5:03 PM / IP Logged Link to Post Post Reply Quote moparguy98
I have a 6200 module from around 2009 and a 7200 module from around 2014. Wondering which one to use. Im using a Blade AL for the immobilizer and the vehicle Is a 2003 Jeep Grand Cherokee. What's the difference?
Platinum - Posts: 7,789
Posted: March 12, 2024 at 9:14 PM / IP Logged Link to Post Post Reply Quote kreg357
Either will work. My preference leans towards the CM7200. While I've never had any issues with the CM6200, my gut thinks the CM7200 handles high current ignition wires better with its separate +12V 30 Amp constant inputs.
Here is a link to a Pictorial on your vehicle : https://www.the12volt.com/installbay/forum_posts.asp?tid=137527
You will need a 1,300 ohm resister for the Parking Light control via the MUX wire (and possibly a relay).
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
