Diode Question
Forseti
Copper - Posts: 78
Posted: February 12, 2005 at 9:55 AM / IP Logged
What would make a Diode get so hot it burns the plastic on the croimp connectors and turn them green ?
jazzy95tsi
Member - Posts: 36
Posted: February 12, 2005 at 11:03 AM / IP Logged
Too much currentDiode Question -- posted image.
Jeff Diode Question -- posted image.
profuse007
Gold - Posts: 2,015
Posted: February 12, 2005 at 12:32 PM / IP Logged
bad crimping or loose crimping.
Houston,TX
Jschult3
Copper - Posts: 106
Posted: February 12, 2005 at 3:43 PM / IP Logged
All of the above.
RU using 1n4001 or equivalent and is it a 1 amp circuit?
Always Verify Wire information before Connecting! Just a Darn Good DIY'R
Forseti
Copper - Posts: 78
Posted: February 14, 2005 at 10:57 AM / IP Logged
Yes its a 1N4001 and its in the parking light circuit ... the one that came with the alarm burned and now this one .... I cant figure it out
Forseti
Copper - Posts: 78
Posted: February 14, 2005 at 12:38 PM / IP Logged
A local car alarm place gave me a 1N5401 diode to use ..... can I use this ?
jazzy95tsi
Member - Posts: 36
Posted: February 14, 2005 at 5:02 PM / IP Logged
Yes the 1N5401 is rated for 3 Amp instead of ! Amp.
Forseti
Copper - Posts: 78
Posted: February 15, 2005 at 5:08 PM / IP Logged
Now I have people telling me not to install a diode ... to just connect without it .... would leaving it out cause any problems ?
iskidoo
Silver - Posts: 1,048
Posted: February 15, 2005 at 9:30 PM / IP Logged
The output from most Alarm/remote start/keyless entry units is typically rated at 10amps so i wouldn't think you even need the diode. What year/make/model is the vehicle?
Forseti
Copper - Posts: 78
Posted: February 16, 2005 at 5:14 PM / IP Logged
Its a 99 Dodge Dakota ... Also its a Clifford Avantguard 4 alarm
