section of site for known vehicle problems
thenzero
Member - Posts: 20
Posted: November 09, 2017 at 8:05 AM / IP Logged Link to Post Post Reply Quote thenzero
Recently you may have seen this thread: no heat on ford fusion
Which got me thinking- bogucki wouldn't have had this issue if he'd had a place to check before the install for known issues with that specific vehicle. What I'm imagining is something like the "Vehicle Wiring" button we've got now, but for a list of known issues by make/model/year, and maybe a corresponding forum to go with it. So for example, if you clicked on Ford/2006 Fusion, you'd get a link to the post with the TBS describing the heating issue and any other relevant posts, so you could go check that before an install just like you normally would check the wiring. Might save some folks a lot of hassle...
thenzero
Member - Posts: 20
Posted: November 09, 2017 at 8:07 AM / IP Logged Link to Post Post Reply Quote thenzero
Further suggestion: if you added a mechanism for people to nominate threads for inclusion, it might make it easier to get off the ground.
the12volt
Administrator - Posts: 3,955
Posted: November 09, 2017 at 8:13 AM / IP Logged Link to Post Post Reply Quote the12volt
If I see enough topics that fall into this category to warrant adding this new forum, I'll add it.
section of site for known vehicle problems -- posted image. the12volt • Support the12volt.com
thenzero
Member - Posts: 20
Posted: November 09, 2017 at 10:57 AM / IP Logged Link to Post Post Reply Quote thenzero
Cool. Here are the results of some searching and reading, most of these are people posting a problem which was later resolved by themselves or someone else posting a service bulletin on their car. I filtered out all the ones that were service bulletins on specific systems, antennas, etc but maybe you want those too...This is by no means an exhaustive list, just some quick search results to show that it might be useful.
https://www.the12volt.com/installbay/forum_posts.asp?tid=35301&tpn=2
https://www.the12volt.com/installbay/forum_posts.asp?tid=50804&tpn=1
https://www.the12volt.com/installbay/forum_posts.asp?tid=57326&tpn=2
https://www.the12volt.com/installbay/forum_posts.asp?tid=105207&tpn=2
https://www.the12volt.com/installbay/forum_posts.asp?tid=111928&tpn=2
https://www.the12volt.com/installbay/forum_posts.asp?tid=1610
https://www.the12volt.com/installbay/forum_posts.asp?tid=3037
https://www.the12volt.com/installbay/forum_posts.asp?tid=3642
https://www.the12volt.com/installbay/forum_posts.asp?tid=11181
https://www.the12volt.com/installbay/forum_posts.asp?tid=13181
https://www.the12volt.com/installbay/forum_posts.asp?tid=16651
https://www.the12volt.com/installbay/forum_posts.asp?tid=20076
https://www.the12volt.com/installbay/forum_posts.asp?tid=25870
https://www.the12volt.com/installbay/forum_posts.asp?tid=47600
https://www.the12volt.com/installbay/forum_posts.asp?tid=49445
https://www.the12volt.com/installbay/forum_posts.asp?tid=59694
https://www.the12volt.com/installbay/forum_posts.asp?tid=66874
https://www.the12volt.com/installbay/forum_posts.asp?tid=71772
https://www.the12volt.com/installbay/forum_posts.asp?tid=69476
https://www.the12volt.com/installbay/forum_posts.asp?tid=74094
https://www.the12volt.com/installbay/forum_posts.asp?tid=77216
https://www.the12volt.com/installbay/forum_posts.asp?tid=82445
https://www.the12volt.com/installbay/forum_posts.asp?tid=87870
https://www.the12volt.com/installbay/forum_posts.asp?tid=90918
https://www.the12volt.com/installbay/forum_posts.asp?tid=98510
https://www.the12volt.com/installbay/forum_posts.asp?tid=104596
https://www.the12volt.com/installbay/forum_posts.asp?tid=105898
https://www.the12volt.com/installbay/forum_posts.asp?tid=112352
https://www.the12volt.com/installbay/forum_posts.asp?tid=117039
https://www.the12volt.com/installbay/forum_posts.asp?tid=118599
https://www.the12volt.com/installbay/forum_posts.asp?tid=111895
https://www.the12volt.com/installbay/forum_posts.asp?tid=123823
https://www.the12volt.com/installbay/forum_posts.asp?tid=129747
https://www.the12volt.com/installbay/forum_posts.asp?tid=130496
the12volt
Posted: November 10, 2017 at 9:38 AM / IP Logged Link to Post Post Reply Quote the12volt
Some of the posts you listed above simply say there is a TSB or there may be a TSB, but do not display the TSB. Currently there is a miscellaneous (Misc.) entry in the vehicle wiring application that can be used for such info and in a few cases is used for such info, but I just added a dedicated TSB field. As I see information about "known issues", I'll add them to the appropriate field/record or create a new one if need be.
I've also added a new category to the downloads application for "Vehicle Technical Service Bulletins" that any member may add files to if they have them.
thenzero
Member - Posts: 20
Posted: November 10, 2017 at 12:40 PM / IP Logged Link to Post Post Reply Quote thenzero
Cool!
Tuesday, June 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
