Reverse Wire, Backup Camera, 2015 Hyundai Santa Fe
garrys
Member - Posts: 7
Posted: August 13, 2023 at 12:49 PM / IP Logged Link to Post Post Reply Quote garrys
I am installing an aftermarket stereo in my 2015 Hyundai Santa Fe, and I cannot get the backup camera to trigger when I shift into reverse. I have purchased the 3 harnesses I need to simplify the job, including the Axxess harness to retain the factory camera. I’m obviously missing a wire somewhere. Any insights are appreciated.
cpalmer
Copper - Posts: 109
Posted: August 13, 2023 at 3:10 PM / IP Logged Link to Post Post Reply Quote cpalmer
Are you using the AXDIS-HK1?
garrys
Member - Posts: 7
Posted: August 13, 2023 at 4:10 PM / IP Logged Link to Post Post Reply Quote garrys
I am using the Axxess AXBUCH6V-HK2, which fits the one connector coming out of the vehicle’s dash. For the power and speaker harnesses, I bought Red Wolf, which are perfect. The stereo with Carplay etc work fine. I believe I have the 6volt converter connected correctly. I’m just missing something with the backup camera.
cpalmer
Copper - Posts: 109
Posted: August 13, 2023 at 5:31 PM / IP Logged Link to Post Post Reply Quote cpalmer
Sounds like your missing the wire that will trigger the radio to know the car is in reverse. Not familier with Red Wolf but there should be a trigger wire on the radio that needs to be connected to the reverse trigger wire in the car. Anything like that on the radio?
garrys
Member - Posts: 7
Posted: August 14, 2023 at 7:01 AM / IP Logged Link to Post Post Reply Quote garrys
I have one brown wire connected to the 6v adapter. But I’m thinking there’s another reverse wire needed, perhaps from the HK2 harness?
cpalmer
Copper - Posts: 109
Posted: August 14, 2023 at 4:27 PM / IP Logged Link to Post Post Reply Quote cpalmer
Brown from the stereo? you need a wire from the car that goes positive when in reverse.
garrys
Member - Posts: 7
Posted: August 14, 2023 at 5:13 PM / IP Logged Link to Post Post Reply Quote garrys
I have the (brown) radio reverse wire, which is connected to the blue/white wire of the 6v converter. What needs to also connect there is the VEHICLE’s reverse wire…that’s what I can’t locate. I’ve tried the multimeter…there is power to the stereo (which I already knew because the stereo works). I can’t however verify any power to the HK2 harness, either because there is none or because I can’t get the tips of the multimeter into the harness wiring. My plan was to find the wire that changes when I shift into reverse and use that one. So I am stuck.
garrys
Member - Posts: 7
Posted: August 14, 2023 at 7:26 PM / IP Logged Link to Post Post Reply Quote garrys
I had an opportunity to tinker around today (the vehicle in question is my son’s and we basically function on opposite schedules, so I get these occasional chances to work on it). I found a wiring error in the power harness, and I can now get the camera to turn on (which I was previously unable to do). But it’s on continuously. So I still need the reverse trigger wire. Not sure if this helps but at least it’s a bit of progress. Thanks for any suggestions.
cpalmer
Copper - Posts: 109
Posted: August 14, 2023 at 7:56 PM / IP Logged Link to Post Post Reply Quote cpalmer
should be a 12 pin plug that you are getting video signal from , in there is a Red w/ black stripe wire ( at least on the vehicle side not sure what color the Axxess harness makes it). This wire should go on and off with the vehicle reverse lights
garrys
Member - Posts: 7
Posted: August 14, 2023 at 8:14 PM / IP Logged Link to Post Post Reply Quote garrys
I’ve seen the black/red wire on the Hyundai wiring. Should I tap into that? I was hoping to avoid that by using the Axxess harness. Thanks for your help by the way…much appreciated.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
