Routing Lexan?
D'Ecosse
Copper - Posts: 49
Posted: October 25, 2004 at 1:35 AM / IP Logged
Anyone routed Lexan? My friend needs some louvre slots cut in a rear window /engine hatch. I don't think it will be a problem, but any advice would be appreciated re cutting speed etc. I figured I'd try to keep the bit speed down a little, keep the tool moving & try to "bite" as little as possible. I'll lay out the pattern on MDF and just use that as a template with a pattern cutter.
Alpine Guy
Platinum - Posts: 2,478
Posted: October 25, 2004 at 8:49 PM / IP Logged
i seen on tv where the guy took a razor blade, , "very sharp one"  Cut the lexan as deep as possible in 1 or 2 passes,,,then pour alcohol in the groove, , light it on fire and bend it off.   It cuts perfect.   But that was for big curves and straight lines, , , if its a really tight curve, then that prolly wont work.
chrane
Member - Posts: 27
Posted: October 26, 2004 at 8:50 PM / IP Logged
lexan is easy to router, but get a friend or hire an imigrant to spray wd-40 on the blade and the plastic every 2 seconds or so to keep it cool so it cuts smooth
Aaron
CarAudioHelp
Copper - Posts: 198
Posted: October 27, 2004 at 8:50 AM / IP Logged
You've got the right idea with the MDF pattern. A tip to improve and reduce your finishing time. Make two templates, one about 1/16" bigger than your finished template. Route to that line first and then go back and finish off with the correctly sized template. By removing only a small layer on the final pass you will get less chipping which means less sanding/buffing.
D'Ecosse
Copper - Posts: 49
Posted: October 27, 2004 at 9:29 AM / IP Logged
CarAudioHelp wrote:
...Make two templates, one about 1/16" bigger than your finished template. Route to that line first and then go back and finish off with the correctly sized template. ....
That's a great tip! Thanks!
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
