2003 Jeep Grand Cherokee, Add Powered Sub To Infinity System
kw4tx
Member - Posts: 48
Posted: May 04, 2022 at 10:24 AM / IP Logged Link to Post Post Reply Quote kw4tx
I have a 2003 Jeep Cherokee Laredo with an Infinity system. I want to add some low-end to the system. I don't want the teeth-rattling window bowing system. I am keeping the factory radio
My question is can I tap into the Infinity amp to run stuff like remote wire and use high-level inputs to the sub/amp
I will of course use a separate ground and power wire
If so does anyone have a wire code? TIA
The sub/amp I am planning on using has high level inputs
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
