2005 toyota solara, ignition, starter wires
mysticalp
Copper - Posts: 63
Posted: December 25, 2011 at 1:47 PM / IP Logged
Hello...
I am in need of some advice as I have not encountered this before.  I am trying to hoo up an Autostart to a 2005 Toyota Solara.  The Solara has 2 Ignition wires and 2 Starter wires.  The Autostart (AS-1272) Has a jumper for the 5th relay (Accessories 2 Jumper, Ignition 2 Jumper, Starter 2 Jumper).  My question is: DO I use both jumpers?? (Ignition & Starter) if so, how would I accomplish this as there is only one wire (green) for the 5th relay?  Any advice/help would be much appreciated!
Thanks in advance for your time....
Pete
tedmond
Gold - Posts: 4,610
Posted: December 25, 2011 at 1:50 PM / IP Logged
use the 5th relay for your additional ignition.
the secondary start use a relay and connect like so
85 - ground when running (status output)
86 - start (+) from unit
87 - constant 12v
30 - second start wire.
or
85 - second start (-) from unit
86 - constant 12v
87 - constant 12v
Ted
Compustar Expert
mysticalp
Copper - Posts: 63
Posted: December 25, 2011 at 1:59 PM / IP Logged
That's great!  Thanks for your reply and expertise!  I will do this and let you know.  I will use your first method.  Thanks again!
Pete.
Pete
Posted: December 25, 2011 at 6:16 PM / IP Logged
First method, GWR to 85 is safer, that way there's NO continuity between the starter wires.
Except if you only have one GWR and it's already running a by-pass, don't forget to diode them away from each other.
mysticalp
Copper - Posts: 63
Posted: December 25, 2011 at 11:13 PM / IP Logged
Thanks for the tip howie II.  I used the first method and everything checked out!  Your input and help is very much appreciated!
Pete
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
