98 lumina, bulldog remote starter
mikejr0046
Posted: December 26, 2003 at 6:20 PM / IP Logged
Trying to hook up bulldog remote starter,lookin for the ignition wires one and two.Bulldog says pink and violet.I found two pinks and one violet that are hot when in the run position.How do i know which one to use?The other thing is these are both light gauge wires 16 or 18, the wires from bulldog are alot heavier.
mikejr0046
Teken
Gold - Posts: 1,492
Posted: December 26, 2003 at 8:19 PM / IP Logged
The wire you require will show +12 volts in the *ON* and *CRANK* position.
Or as it is stated in other manuals it is the wire that shows 0 volts in the *OFF* & *ACCESSORY* position. And 12 volts in the ignition while in the *START* and *RUN* position.
I hope that helps.
Regards
EVIL Teken . . .
muaiad97
Copper - Posts: 207
Posted: December 27, 2003 at 10:42 PM / IP Logged
This is wiring daiagram  lumina 1998
+12 v       red
starter      yelow
ign#1   pink
ign#2  brown
acc   orenge
JWorm
Platinum - Posts: 2,208
Posted: December 28, 2003 at 10:11 AM / IP Logged
The pink wire will be about 12 gauge. You have the wrong wires. Some GM's have a 16 gauge second ignition or starter wire, but not this vehicle if I remember correctly.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
