05 F-150 & bypass, which one?
saleen49
Copper - Posts: 99
Posted: March 05, 2005 at 10:01 AM / IP Logged
 Just picked up an 05 FX4 F-150 with pats s-key and narrowed down to pypass 555f or 556u but not sure which is better, getting a spare key from work is not a problem,
 thanks
gcote
Member - Posts: 6
Posted: March 05, 2005 at 10:10 AM / IP Logged
the 556u is the best way to go. the 555f can be a bit of a pain triing to get that pellet in the right spot and still be able to reinstall the column.
turn us on
gcote
Member - Posts: 6
Posted: March 05, 2005 at 10:12 AM / IP Logged
do you already know about the gem module in that truck?
turn us on
Bnluis
Silver - Posts: 578
Posted: March 05, 2005 at 10:21 AM / IP Logged
555F won't work on that truck , use a 556U and a spare key. As far as the GEM module,  it  can sometimes be disable the sleepy locks, read the owners manual, it is called "  door lock Inhibit". But simetimes it not neccesary. Ford stop using that feature on some of their newer models.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
saleen49
Copper - Posts: 99
Posted: March 05, 2005 at 11:01 AM / IP Logged
 Yes,It does have a gem module,
saleen49
Copper - Posts: 99
Posted: March 05, 2005 at 11:06 AM / IP Logged
 I installed a Mannix remote/alarm on my 03 Taurus, I assume it has the sleepy locks, works great
mxxmikexx
Silver - Posts: 796
Posted: March 05, 2005 at 1:06 PM / IP Logged
forget the dei module, trilogix has a great module that learns the code and you dont lose a key,and you dont even have to tear apart the column shroud.PKF3 is the part# www.transponderbypass.com
the 555f is a joke. DEI is way behind on their interfaces
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
