96 integra SE Alarm/Keyless entry
sparta904
Posted: May 16, 2005 at 11:09 PM / IP Logged
okay, first time posting here, i need to know where i can find a diagram for my 96 integra SE (5spd), i bought an used alarm/keyless entry kit, and want to "try" to install myself if its not complicated, does anyone know what exacly i will be needing, and if its difficult? thanks
p.s. i searched the forum and could not find what i was looking for thats why i posted this
mo12v
Posted: May 16, 2005 at 11:22 PM / IP Logged
Constant 12 voltsWHITE/ BLACKIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK / YELLOWIGNITION SWITCH HARNESS
StarterBLACK/ WHITEIGNITION SWITCH HARNESS
Dome LightL GREEN/ RED (-)14 PIN GRAY CONN. IN DR. KICK PANEL
Trunk Pin SwitchGREEN (-)10 PIN GRAY CONN. IN DR. KICK PANEL
Parking LampRED / GREEN (+)AT HEADLIGHT SWITCH *
Power LockBLACK/ WHITE14 PIN GRAY CONNECTOR
Power UnlockBLACK/ REDIN DRIVER KICK PANEL
* RED / BLACK (+) In 18 Pin BROWN Connector In Driver Kick Panel Can Also Be Used For Parking Lights.
Negative Pulse Door Locks
Accessories
Window UpD\ RED / YEL P\ BLU/RED D\ GRN/YEL P\ YELLOW @ MAIN SWITCH
Window DownF/ RED / BLU F/ BLU/WHT R/ GREEN R/ YEL/GRN
Ign Key WarnBLUE/WHITE (-)STEERING COLUMN HARNESS
Trunk ReleaseN/ACABLE OPERATED
OEM HornBLUE/GREEN (-)STEERING COLUMN HARNESS *
HeadlightsRED / WHITE (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/AOEM ALARM MUST BE PUT INTO VALET MODE
OEM Alarm DisarmN/ATO DISARM WITHOUT OEM TRANSMITTER
Reversal Rest At Ground Power Window Circuit .
* BLUE/GREEN (-) Also Located In 3 Pin GRAY Connector At Fuse Block Behind Driver Dash.
Remote Start
Tach SignalBLUEAT DISTRIBUTOR OR TACH TEST CONN. *
Ignition #2YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryWHITE/ BLACKIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPEOEM SWITCH OPENS STARTER CIRCUIT
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightGREEN/ BLACK (+)14 PIN GRAY CONN. IN DR. KICK PANEL
Rear Window DefrostYELLOW (-)16 PIN GRAY CONN. ABOVE FUSE BLOCK
* Distributor Located On Passenger Side Of Engine. Tach Test Connector Is a 2 Pin GRAY Connector Located On Driver Rear Of Engine On Strut Tower. Tach Wire Also Located In 16 Pin GRAY Connector Above Fuse Block Behind Driver Dash (LS & GS-R Models) Or 14 Pin Connector Above Fuse Block (RS Models).
MO
thepencil
Gold - Posts: 1,526
Posted: May 17, 2005 at 9:14 AM / IP Logged
Very straight foward install depending on the type of keyless unit you are getting. You will need a Digital Multimeter. Best thing to do is ask questions if you feel you don't quite understand something or concept. You will be surprise at the help you can get on this site.
DIRECTWIRE™ WIRING INFORMATION - ACURA / INTEGRA / 1996 / Keyless Entry
12volts white to WHITE/ black (50A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Ignition BLACK / YELLOW   +   ignition harness
Power Lock BLACK/ white   -   driver kick panel
Notes: In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch.
Power Unlock BLACK/ red   -   driver kick panel
Lock Motor WHITE/ red   5wi driver kick, door harness
Unlock Motor yellow/red   5wi driver kick, door harness
Parking Lights+ RED / black   +   green plug above fusebox
Notes: Also a male blade terminal is available in fuse box.
Parking Lights- blue/red   -   factory alarm (if equipped)
Notes: The factory alarm is under the driver seat.
Hazards same as turn signal wires
Turn Signal(L) GREEN/ blue   +   steering column
Turn Signal(R) GREEN/ YELLOW   +   steering column
Door Trigger lt. GREEN/ red   -   driver kick panel
Notes: Looks like 14 awg wire but mostly insulation.
Dome Supervision use door trigger
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Horn Trigger gray or blue/green   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.96 integra SE Alarm/Keyless entry -- posted image.
sparta904
Posted: May 17, 2005 at 10:50 PM / IP Logged
thanks a lot for everything, now whats a digital multimeter??
thepencil
Gold - Posts: 1,526
Posted: May 18, 2005 at 9:25 AM / IP Logged
Digital Mulitmeter
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
