2005 f150, viper 791
sikassscivic
Member - Posts: 33
Posted: May 07, 2005 at 9:26 PM / IP Logged
same as the older ones,ive done a 2003,i just bought a 2005,so do i use the same kind?
anyone have any tips and maybe a diagram for me2005 f150, viper 791 -- posted image.
Moderator - Posts: 12,488
Posted: May 08, 2005 at 11:21 AM / IP Logged
The 2005 uses a new form of PATS and you will need a different system than the 2003. I use the PKF3 that directly hooks into the PATS wires and doesn't require you to loose a key in the installation & have had 0 problems with any of the customer's vehicles that it was installed into.
sikassscivic
Member - Posts: 33
Posted: May 08, 2005 at 7:48 PM / IP Logged
i bought a pkm1 from you for a mazda maita,i could never get it to work,i tried for hours,i called you,still never got it to work.
sikassscivic
Member - Posts: 33
Posted: May 22, 2005 at 9:18 PM / IP Logged
ok,i bought a viper 791 and the pkf-3 for my 2005 f150.couple questions.
1)the sheet that came with the pkf-3 does not have a little check mark next the 2005 f150,but does have a check mark next to the 2004,so before i even begin,is it going to work on my 2005??
2)it says i need the tx and rx of my ecu,where are these and does anyone have the color and locations i can grab them at?
JiggaFan
Copper - Posts: 71
Posted: May 23, 2005 at 7:27 AM / IP Logged
the tech sheet shows what the tx/rx/gd/ign wires SHOULD be depending on what your plug at the transponder ring on the key cylinder looks like...at least i know that's how the PKF and PKF2 work on '00 Expedition and '03 Focus.
BTW, I've yet to get the PKF or PKF2 to program for the Expedition and Focus I just mentioned.  Not sure if it's user error or bypass module incompatibility, but I've had to use a spare key in a universal bypass on both those vehicles.
sikassscivic
Member - Posts: 33
Posted: May 23, 2005 at 6:32 PM / IP Logged
oh,so if i had a "type a" plug i would just wire it up to those same wires that it shows?do i just splice into them,or do i actually cut any othe wires?there really is no installation instructions at all.just a chart that shows the plugs.
sikassscivic
Member - Posts: 33
Posted: May 23, 2005 at 7:18 PM / IP Logged
sheets keep refering to the BCM,located on the back driver cabin wall.does this mean im going to need to take out my back seat to get to it?i have a supercrew.also,what bypass did you use?
KarTuneMan
Platinum - Posts: 7,056
Posted: May 23, 2005 at 7:38 PM / IP Logged
what wires are you trying to "locate"
mxxmikexx
Silver - Posts: 796
Posted: May 23, 2005 at 8:21 PM / IP Logged
just call and talk to their tech guys, they are very helpful over there 1-888-745-2233
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
moshpitmickey
Member - Posts: 43
Posted: May 23, 2005 at 8:36 PM / IP Logged
You should be able to get to the wires without removing the seat . The bypass for remote start is 556S, 555U, or 556U. These are DEI part numbers.
moshpitmickey
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
