Dodge Sprinter DEI 727T
customcarelectr
Member - Posts: 43
Posted: November 15, 2006 at 9:57 PM / IP Logged
I am about to do my first alarm on a 2006 sprinter. I am using the 727 so the driver can retain his factory keyless remote. The factory keyless is the mercedes switchblad style keyfob combo.
Does anyone have and difficulties to share, anything I should watch out for?
Where are the door triggers easiest to find.  front, side and back?
Thanks in advance
josh1979
Silver - Posts: 320
Posted: November 15, 2006 at 11:44 PM / IP Logged
 WIRING INFORMATION - DODGE / SPRINTER / 2006 / Remote Start
12volts red (100A)  +  ignition harness
Starter BLACK / YELLOW  +  ignition harness
Second Starter N/A
Ignition black  +  ignition harness
Second Ignition BLACK/ red  +  ignition harness
Third Ignition N/A
Accessory gray/dk. green  +  ignition harness
Second Accessory N/A
Keysense blue/black  -  ignition harness
Power Lock WHITE/ yellow  -  sw on dash or CTM, pink plug, pin 7
Notes: Negative pulses on this wire will alternate between lock and unlock.
The CTM (Central Timer Module) is under the driver seat.
If you encounter a problem with the door locks getting out of synch when using this wire, then use the door lock motor wires instead for lock/unlock. See DirectFax document 1700 for wiring information.
Power Unlock same as power lock wire
Lock Motor blue/red  5wi DKP or CTM, pink plug, pin 2
Notes: The CTM (Central Timer Module) is under the driver seat.
Unlock Motor BLACK/ red  5wi DKP or CTM, pink plug, pin 3
Parking Lights+ gray/black (L), gray/red (R)  +  fuse box, blk 15 pin plug, pins 4, 6
Notes: Use both wires and diode isolate each.
Parking Lights- N/A
Hazards dk. GREEN/ YELLOW  -  SKREEM, pin 10
Notes: The SKREEM (Sentry Key Remote Entry Module) is under the driver seat.
Turn Signal(L) BLACK/ white  +  fuse box, blk 15 pin plug, pin 8
Turn Signal(R) BLACK/ dk. green  +  fuse box, blk 15 pin plug, pin 5
Reverse Light WHITE/ red  +  blk 12 pin plug under cluster, pin 1
Door Trigger BROWN / white  -  driver kick, door harness
Dome Supervision common with door trigger wire
Trunk/Hatch Pin BROWN / white  -  rear pin switch or interior light
Hood Pin BLACK/ blue  -  pin switch or SSM, brn plug, pin 14
Notes: This wire rests at ground, then goes to an open circuit when the hood is open.
The SSM (Security System Module) is under the driver seat.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm red  -  DKP or SSM, brown plug, pin 21
Notes: The SSM (Security System Module) is under the driver seat.
Factory Alarm Disarm black  -  DKP or SSM, brown plug, pin 20
Disarm No Unlock see factory alarm disarm
Tachometer dk. GREEN/ YELLOW  ac  data link connector, pin 3
Notes: The data link connector is under the driver side dash.
Wait to start
Brake Wire BLACK/ red  +  brake pedal switch
Notes: The brake wire only works with the ignition on.
Parking Brake BROWN / black  -  parking brake switch
Horn Trigger BLACK / YELLOW  -  horn switch
Notes: The horn trigger only works with the ignition on.
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Dodge Sprinter DEI 727T -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
bring back the rotary phone so i dont have to press 1 to proceed in english
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
