pulsed to steady output
xtremespeed
Member - Posts: 38
Posted: June 28, 2014 at 10:18 PM / IP Logged
I am using the "Pulsed to steady output" diagram for a vehicle turn signal application and ran in to a small snag. My factory turn signal wire, instead of switching from +12v to open, actually switches from +12v to ground, which discharges the capacitor. Is there a modification I can make to the circuit to prevent this?
Platinum - Posts: 13,725
Posted: June 28, 2014 at 10:37 PM / IP Logged
Insert a diode
Posted: June 28, 2014 at 10:40 PM / IP Logged
xtremespeed
Member - Posts: 38
Posted: June 28, 2014 at 10:45 PM / IP Logged
i am an idiot wrote:
https://www.the12volt.com/relays/relaydiagram22.html
I am using both diodes just like that diagram. It works if the turn signal just switches from hot to open, but mine switches from hot to ground and when it does it discharges the capacitor and the relay clicks off.
oldspark
Gold - Posts: 4,913
Posted: June 28, 2014 at 11:19 PM / IP Logged
Replace the diode or check that it isn't shorted.
It cannot work yet discharge. If the diode is in the wrong direction, the relay won't turn on.
If it turns on, the diode won't allow current to return (discharge) to/thru the can side.
And that's true even if the circuit does switch to GND {which I doubt - I think you are seeing the other bulb(s); otherwise what's the circuit r flasher can you are using?}.
Otherwise check your wiring or that you have a BIG capacitor (electrolytic, not a geencap etc).
Posted: June 28, 2014 at 11:26 PM / IP Logged
10,000 microfarad is the capacitor value in the diagram. Is that what you are using?
xtremespeed
Member - Posts: 38
Posted: June 28, 2014 at 11:41 PM / IP Logged
I am using a 4k uf cap. It gives me the perfect delay time to keep my relay on without staying on too long. After trying this on the car and it not working correctly, I'm now bench testing the circuit without any load on the relay. If I apply a pulsed positive/open to the circuit, it works perfectly but if I apply a pulsed positive/negative, as soon as the trigger goes to ground the relay opens. I'm not even using a flasher right now. I'm tapping the trigger wire on a constant hot and constant ground wire. As long as I don't tap it on the ground wire it works fine and the relay stays closed until I quit tapping the trigger wire on the constant hot.
oldspark
Gold - Posts: 4,913
Posted: June 28, 2014 at 11:46 PM / IP Logged
In that case your diode is shorted.
Posted: June 28, 2014 at 11:49 PM / IP Logged
It has to be shorted.
oldspark
Gold - Posts: 4,913
Posted: June 28, 2014 at 11:53 PM / IP Logged
Unless the cap is NOT on the line-end of the diode...
(I know - the assumption is correct wiring - but just in case...)
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
