Using Relays for various items
Un0turb0-wp
Member - Posts: 6
Posted: April 11, 2005 at 3:39 AM / IP Logged
Hi would like to know how i can wire up a relay with a switch to turn on things like my Dash Display, and other 12v accessories in my race car. would it be better then just hard wiring it to a switch direct to the 12v source?
Also what is the best way to wire up a window wiper with a relay?? the wiper motor has 2 speeds would it be best to wire it with 2 relays?
WRT to wiring up headlights, i've found a few diagrams saying this is how you're supposed to wire the lights up, since this is jsut the race car, i only need normal beams ( if that makes sense) and not high beams/brights etc... how can i wire this up..
Thanks in Advance
"Im kept in places by G-Forces not Seatbelts"
Un0turb0-wp
Member - Posts: 6
Posted: April 13, 2005 at 3:23 PM / IP Logged
bump......
popeye004
Copper - Posts: 97
Posted: April 16, 2005 at 12:03 AM / IP Logged
bump!!!!!!! are you serious???????
Un0turb0-wp
Member - Posts: 6
Posted: April 16, 2005 at 2:39 PM / IP Logged
yes i am what makes u think im not?
hotwaterwizard
Silver - Posts: 1,350
Posted: April 16, 2005 at 3:48 PM / IP Logged
Using Relays for various items -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
popeye004
Copper - Posts: 97
Posted: April 16, 2005 at 4:30 PM / IP Logged
there's a good diagram.
hotwaterwizard
Posted: April 16, 2005 at 4:44 PM / IP Logged
Stockton California
Un0turb0-wp
Member - Posts: 6
Posted: April 17, 2005 at 11:00 AM / IP Logged
Thanks a million... :)
royman
Posted: June 07, 2005 at 3:20 PM / IP Logged
check this link http://www.1728.com/project3.htm
ff-mike
Copper - Posts: 199
Posted: June 07, 2005 at 4:05 PM / IP Logged
John- I am not sure in his application, but in the past my wipers have been 4 wired- ground, low, high, and park. Otherwise it looks as easy as you msde it
Mike
Sunday, May 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
